R50/53 Loose repeater - how to tighten?
Old Oct 26, 2007 | 01:39 PM
JAB 67's Avatar
JAB 67
My 2004 MCS just came back from the body shop, and the repeater (that side light, on the side fender with the "S" on it) is loose. How do I tighten it?
Old Oct 26, 2007 | 01:47 PM
Yucca Patrol's Avatar
Yucca Patrol
It just snaps in, so there is no real way to tighten it. If they are removed and replaced multiple times, there is a tendency for them to be somewhat loose afterwards (plastic tabs and such may be bent)
There is a tab at the front and a post at the back that hold it on. I once considered using a dab of silicone caulk on the post when I had a loose fitting piece but replaced that piece with a new one instead.
Old Oct 26, 2007 | 01:49 PM
SRTech's Avatar
SRTech
If it's loose in the rear of the part, you can bend the metal tab in a little if the plastic clip isn't broken. If it's the front that's loose, replace the grommet (part number 51-40-0-766-479). Or you can just silicone it in.
Steve
Old Oct 26, 2007 | 02:09 PM
JAB 67's Avatar
JAB 67
How do I remove it?
Old Oct 26, 2007 | 04:10 PM
SRTech's Avatar
SRTech
How do I remove it?
Pry the front out CAREFULLY and just far enough for the pin to clear the body. Then pull forward.
Steve
Old Oct 26, 2007 | 04:20 PM
rkw's Avatar
rkw
Slide the light towards the rear of the car before prying outward on the front edge. There is not really a way to tighten it -- the plastic tab on the rear side might have been flexed too far and lost some of its springiness. After you take it out, maybe you could apply some tape or other filler to the opening so it would be more snug.
Old Oct 26, 2007 | 04:49 PM
chpsk8's Avatar
chpsk8
Take it back to the body shop? They should have put a new one on if this one is worn out now.
Old Oct 26, 2007 | 04:53 PM
DjR53's Avatar
DjR53
just take it out and put silicone around it and when it dries it will tighten up
Old Oct 26, 2007 | 06:11 PM
PGT's Avatar
PGT
it's not worn out, the metal tab is just bent outwards. this is normal if you remove them.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
Wombat Pie
Navigation/Audio
Oct 5, 2015 08:00 PM
Emnotek
Sep 29, 2015 07:37 AM
