Flywheel/clutch problem??
Old Oct 22, 2007 | 02:58 AM
Silverbullit's Avatar
Silverbullit
On a cold start up I get a loud screeching noise when I let the clutch out. It happens only in first gear maybe once or twice and I don't hear it again until the next cold start up. Is this a sympton of the dreaded flywheel/clutch problem that I've seen on other threads? I have about 2500 more miles before the next inspection but I'm thinking maybe I should take it in now. It's a 250 mile round trip and a whole day at the dealer. Any advice??
Old Oct 22, 2007 | 05:26 AM
Dave_in_Va's Avatar
Dave_in_Va
I have the same thing...my screech isn't really "overly" loud, but it's annoying...sounds like fingernails and a blackboard kind of?
Responses are appreciated!!!
Old Oct 22, 2007 | 05:28 AM
DSRH's Avatar
DSRH
My 2006 MCS has 14500 miles on it and I had the dual mass flywheel and clutch assembly replaced under warranty 2 weeks ago. It was making a noise at idle in neutral. Not loud but it was there. No other noise was present. I believe there is a top secret 00 (double naught) recall on this but if there is I can't repeat it....Go to your dealer and ask them to correct this problem now so you have lots of warranty left in case there are further issues. So far I have not had any other problems as I understand the parts that were put back in my car are an improvement over the initial parts. (I say that as I cross my fingers) You should have no problem getting them to correct this....oh from what I understand you can drive the car like this but it might possibly get a bit worse...
Old Oct 22, 2007 | 07:10 AM
flannery's Avatar
flannery
I have a 2004 MCS that had this same problem. It was just as I let out the clutch and only a couple of times before it went away. I have 36000 miles and it had been doing it for quite a while. I took it to the local Mini Dealership (Flow Mini in NC) and they said it was a fluid leak that was getting onto the clutch plate and flywheel. They replaced both under warranty and fixed the leak and I have been squeek free ever since. If you search you can find the sound described as a screach, bark, squeek and other names but the fact that it only happens when the car has been sitting around a while and only happens the first few times you let out the clutch is the real telling factor.
Mike
Old Oct 22, 2007 | 08:01 AM
Silverbullit
Is there an offical recall on this problem or is it up to the Dealer to make or not make the repair. I can just hear the famous,"they all do that" line as they send you back out the door. I would like to have some kind of proof in order to plead my case. Any advice??
UncDeo
Nov 4, 2019 04:08 AM
tylewis
Sep 6, 2015 01:07 PM
mikeandtricie
Sep 4, 2015 01:42 PM
mimaal
Sep 4, 2015 09:09 AM
Sep 2, 2015 09:05 AM
