Widest tires possible
What is the widest 16" tire that will fit on a stock ride hight 04 mini cooper s?
Also just for the fun of it what is the largest 17" tire that will work?
Thanks for your help
To get to the question: It depends on your wheel (which in turn depends on offset and use of spacers or not). Also dependent are whether you intend to do some body/fender work to make sure you won't have problems with scrub radius.
Anyways, the max sizes I have seen are in the 225-235 range.
- Matt
https://www.northamericanmotoring.co...ad.php?t=62253
https://www.northamericanmotoring.co...d.php?t=112010
Also check the autocross forums, there are many extra wide tires that are used but realize that the widest possible tires will limit your tire selection.
Why do you want wide tires anyway? For Looks?
Personally I like 275/35-15
https://www.northamericanmotoring.co...ad.php?t=87381
Please post in the correct forum.
The widest tire that will fit will depend on which rim you use and how willing you are to trim the wheel well arch plastic or buy wider fenders.
Assuming a normal MINI with stock suspension.
If you find 16x8" rims like Rota Slipstream
4x100 bolt pattern with +34mm offset the outer edge of the rim is almost flush with the outer edge of the plastic arch. If you choose +45 or +48 offset and the rim is wide like 8" then there will be not enough clearance for the rear lower trailing arm- you'll need a 10mm spacer to push the wheel outwards for clearance.
You'll need to buy tires that are smaller than stock to have the best clearance and certainly not taller than stock or you'll risk rubbing. Realize that wider rims and wider tires means more weight so for street driving at normal speeds this isn't helpful but for track use or autocross with no speed limits then wider tires and sticky rubber is very helpful- also wears out fast.
225/45-16 will fit 16x8 rims (fits 7-8.5" rims) 23.9" tire diameter
Kumho Ecsta SPT (Ultra High performance Summer tire) $100 each
320 treadwear
and
245/45-16 will fit 16x8 rims (fits 7.5-9" rims) 24.6" tire diameter
Bridgestone Potenza RE750 $134 340 treadwear
Fuzion ZRi $89 320 treadwear
Yokohama AVS ES100 $109 280 treadwear
Stock MINIs will lack the front negative camber needed to make full use of the front tires- stock MINIs will tend to wear out the front outer edges of the tires very fast when doing performance driving- the inner edges are hardly worn.
If you have 17x8 rims (watch the offset, about +35mm) then
you can mount
235/40-17 fits rims 8-9.5" wide 24.4" tire diameter
or
245/40-17 fits rims 8-9.5" wide 24.7" tire diameter
Both available in Fuzion ZRi
Search for the answer, it's been discussed before.
275/35-15 to fit the MINI.
You do need to cut the wheel arch plastic a lot to make it fit.
http://www.tirerack.com/tires/Sizes....rtnum=735ZR5A6
Fits rims 9-11" wide,Perfect for 9.5" wide rim, 20 lbs! Section width 10.8", Tread width 10.1", 23" tire diameter
Compare with what I use on a 15x8" rim.
225/45-15 same Hoosier A6 tire
Fits rims 7-9" wide,Perfect for 8" wide rim, 20 lbs! Section width 9.8", Tread width 9", 22.8" tire diameter
Be aware that after you put in tires that large, ask yourself what sort of street wheels and tires you'd want to install for daily use. If you have a track only MINI then it's fine.
So if I Auto x and do track I CAN use a 235 or 245 ?
offset 35 (the tracklites i am looking at are ET 42 so spacers may be needed...?
Ohhh and so many 235 and 245 40s are on back order
i need a set up fot next seasion starting in march and want to be ready ...
hello "hue"
Motegi Track Traklite Flat Black 17x7 +42mm offset 14 lbs $280 each
235 or 245mm wide tires need rims 8" or wider not 7".
Do you have a source for 17x8" Traklites?
When you put a wider tire on a narrow rim expect tramlining when doing street driving on grooved surfaces such as highways.
When I search Tirerack I can only find
Check ebay or/and in tirerack.com under mr2 spyder rear fitments...
The Traklite2 17x8" 4x100's have a +42mm offset. I want to get a set for my R56, but I was hoping to avoid spacers.
Americas Tire (my local choice for all my other cars rims and tires ...and the street KDW2s) can get 17 x 8.
But a ET of 42 will put me on my fender (VERY modified and trimed already)
that is why I thought I was after a 45 ET (or more) then space as needed
These will be track / auto-x only with either Hoosiers or the BFG R1
TRAKLITE 2.0 Teflon® Black
1-piece forged alloy, painted center, machined lip
TRAKLITE 2.0 Silver
TRAKLITE 2.0 Glossy Black
TRAKLITE 2.0 Silver
Part No. 2312-7849
Size 17 x 8
Offset 42
Backside 6 1/8
Bolt Pattern 4x100
Weight 14 lbs
Size 17 x 8
Offset 42
Backside 6 1/8
Bolt Pattern 4x100
Weight 14 lbs
