Drivetrain 15% SC pulley belt life
Old Oct 17, 2007 | 06:57 AM
Larry Clemens's Avatar
Larry Clemens
I have a 2005 MCS with a 15% SC pulley and stock belt. It was installed February of 2005 but only has about 10,000 miles. How often should the belt be changed?
Old Oct 17, 2007 | 08:08 AM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
Perferably once a year. two tops .. after that I personally dont trust it.. no matter what belt i use. This is after Busting 2 belts.
Old Oct 17, 2007 | 10:50 AM
ThumperMCS's Avatar
ThumperMCS
I was just begining to wonder the same thing...
I have just over 37k miles on my 05 MCS, and the JCW belt that I use with my 15% was put on at just over 1k miles. Never have changed it.
Old Oct 17, 2007 | 10:52 AM
Yucca Patrol's Avatar
Yucca Patrol
These belts will show signs of wear long before they must be replaced. Best just to inspect it and replace as you see fit. I replaced my stock belt at about 45k when I got my 15% pulley. Now I am at 76k and that "new" belt is just fine.
Old Oct 17, 2007 | 10:54 AM
ThumperMCS's Avatar
ThumperMCS
Yea I've looked down at it, and it looks perfectly fine to me. Just wondering how long they usually last.
Old Oct 17, 2007 | 10:58 AM
jaynicholson's Avatar
jaynicholson
I suggest also checking the indicator on the tensioner. After nearly 2 years and 20k miles with a stock pulley and m7 16% pulley I'm overdue. See attached for what I mean.
https://www.northamericanmotoring.co...69&postcount=9
Old Nov 18, 2007 | 01:26 PM
1FSTMINI's Avatar
1FSTMINI
i guess ur not hard on your car. i have to change mine within a year no matter what type ive used...
Old Nov 18, 2007 | 03:32 PM
minimusprime's Avatar
minimusprime
I change mine every 10k.
Old Nov 18, 2007 | 04:53 PM
ThumperMCS's Avatar
ThumperMCS
I just had mine double checked, and much like I thought, it's in perfect condition. Its in perfect shape after a pretty hard 40k miles.
Maybe my dealer changed it sometime without me knowing?? I dunno.
Old Nov 18, 2007 | 05:08 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Under normal street use about every 2 years or about 20,000 miles or which ever comes first.
Under track conditions every 6 months.
I usually change once per year about 8000 miles or less. After 6 belt changes only one was frayed (6 months of wear- mostly street use), none broke, most were fine.
Old Nov 18, 2007 | 05:27 PM
AstroBlackS's Avatar
AstroBlackS
How hard is it to change the belt? What exactly is involved? Do you have to jack up the motor such as when the pulley is installed?
Old Nov 18, 2007 | 07:30 PM
minihune's Avatar
minihune
https://www.northamericanmotoring.co...ad.php?t=81741
See post #10
You need the belt tensioner tool
and a small thin screw driver or similar sized ice pick.
Basic tools
Remove the passenger front tire and wheel well plastic- pulled back is OK.
You would jack up the motor if you had to remove and replace the belt tensioner part itself but not for replacing the belt. 30-40 minutes usually.
Old Nov 18, 2007 | 07:54 PM
RedSkunk's Avatar
RedSkunk
Sitting at 38k miles and 1.5 years, like others mine looks fine / seems fine. I'd imagine you'd want to change more often than necessary if you're looking for that last nth of performance. Or if you're using a belt-shredding 19% reduction pulley... :P
Old Nov 18, 2007 | 10:00 PM
1FSTMINI's Avatar
1FSTMINI
speak of the devil....i lost one rib the other day and final got to my friends house today for the tensioner.
decided to go out tonite and jumped on it "alittle bit" and heard something fly under the car and the boost dropped and the s/c started gargglin....lost have the belt. im off tomorrow so im gonna put the lightened crank pulley i bought on and a new belt. yay
Old Nov 19, 2007 | 08:43 AM
minimusprime
just as an fyi... you won't notice a slipping belt on the butt dyno. The belts depredation to slipping is such a slow process that you ease into it. After seeing mini's on the dyno I think a lot of people are driving around with belts that are slipping without noticing it. Since belts cost about 15 bux... I see no reason for that.
I look at it this way. Change the belt is an amazingly easy process. Scoop up one of those bmw tools and your 75 in the hole. But have a tech change your belt twice and you're also 75 in the hole. Buying and switching belts often is cheap insurance that your car is running at the optimum performance level. It's also quite easy, experienced techs such as way of waymotorworks can do it only having to remove the front lower plastic skirt and that's it in about 10 minutes. This means by the second time you do it... I'd bet you're down to 30-40 minutes as a diy. If you can change your own oil, you can definitely change your belt.
Old Nov 19, 2007 | 11:28 AM
1FSTMINI's Avatar
1FSTMINI
def a easy swap out....took me about 30mins cuz i have fat hands so i took off the wheel and pulled the liner back.
i had 2 ribs left on the belt.
Old Nov 19, 2007 | 11:31 AM
sprp85's Avatar
sprp85
i did it with my passenger side wheel off and liner pulled..
is there any easier way?? i gotta perform another swap soon and I don't feel like pulling all them bolts out again...
Old Nov 19, 2007 | 06:00 PM
ED955S's Avatar
ED955S
What replacement brand do you guys use? Any part number/s for 15% red. pulley?
Old Nov 20, 2007 | 06:43 AM
RedSkunk's Avatar
RedSkunk
https://www.northamericanmotoring.co...d.php?t=120478
Check hornguy's post (4th). NAPA 060535 is recommended by John of LDG.
Old Nov 20, 2007 | 07:35 AM
1FSTMINI's Avatar
1FSTMINI
...isnt john NEW to the mini scene. so how would he know which belt is better for these cars.
p.s.....ive def know ive been doin this longer than him and havent noticed a difference in any belt used as long as its the right size
Old Nov 20, 2007 | 07:42 AM
minimusprime
I wouldn't say he's new to it at all. I notice a difference between a 539 and a 535.
Old Nov 20, 2007 | 07:45 AM
1FSTMINI's Avatar
1FSTMINI
which do you use and what differences are you seeing?
then im mistaken....just never really heard of these guys and hear people say "they" rec it.
Old Nov 20, 2007 | 08:21 AM
xsmini's Avatar
xsmini
I change mine about every 30k, I've been using the one from Mini for the JCW set up. So far they have all looked fine when I replaced them, just did it because I don't like being stuck.
Nik
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
The_Kid
Nov 3, 2016 06:30 PM
M7Speed
Sep 3, 2015 07:48 AM
