R50/53 BLAH... I failed NYS Inspection
Old Oct 2, 2007 | 02:26 PM
peekinde's Avatar
peekinde
When we turn on the headlamps on the mini, the headlights come on and the 2 lamps under the headlights come on as well. The one between the fog and headlights.
Well.. one of them is broken but my indicator lights in the same housing is working fine!
Other new cars don't even have the lamp that we have, does anyone have a NYS inspection checklist?
Old Oct 2, 2007 | 03:11 PM
CooperGear's Avatar
CooperGear
From: Greater Chicagoland. Ich Bin Ein Midwesterner!!!
Sometimes I am GLAD that here in IL they don't care what you drive. On the other hand I do not want a piece of junk falling apart in front of me.
Old Oct 2, 2007 | 04:15 PM
AutoXCooper.com's Avatar
AutoXCooper.com
I have an 05 Cooper with factory fogs, and that housing unit that holds the turn indicator also holds that other light. Now the bad news, you can change the TI within mins, but the other light is changed by taking OFF the bumper skin. My dealer changed mine once while they had it apart for other reasons.
Good Luck.
Old Oct 2, 2007 | 05:40 PM
peekinde's Avatar
peekinde
Well the place is brought it for inspection said they could change it but it turns out that the wiring is no good, not the bulb!
Old Oct 2, 2007 | 05:42 PM
GrFa's Avatar
GrFa
Yes you failed because one of your marker lights (the other light in the indicator housing) is out. Replace the bulb and go back and get it inspected. I believe one of the requirements for inspection is working marker lights.
Old Oct 3, 2007 | 08:23 AM
jabell2r's Avatar
jabell2r
Coordinator :: M2C2
Not sure about other states but in NY if you have a light, even if it is aftermarket it has to work. Of course if you have a mechanic that you've used for a long time it doesn't usually matter. I found this out after using a coupon and had an aftermarket fog lamp out. Guy tried to get me to pay for whole new set of lights to pass me. Thats what I get for trying to save a buck.
Old Oct 3, 2007 | 08:52 AM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Just get a new bulb. There are 2 of them in there.
Old Oct 3, 2007 | 12:01 PM
peekinde's Avatar
peekinde
I just picked up my car today, my mechanic said the bulb went on for a couple of seconds when it was there overnight so he passed me =D
So its probably because of the humidity that shorted the lights.
But I was charged $40 for new windshield wipers to pass the inspection!
I thought it was rip off since I coulda gotten it at walmart for 4 bucks. But when I saw the car... they were insane! and made the car look so frigin 10x hoter.
Go check them out.. anco contours
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
gknorr
Dec 26, 2016 09:38 AM
vulkandino
Oct 31, 2015 08:29 PM
pkillur
Tires, Wheels, & Brakes
Oct 1, 2015 03:59 AM
EVMini
Sep 28, 2015 10:20 AM
