A fly-by video of my MINI
Hey guys I finally decided to post a video up of my 2003 MINI Cooper doing a fly by!
This is what I have engine wise:
Engine:
(1.6 liter SOHC 115bhp and 110tq stock)
After market intake filter
Magnaflow car-back
Powerflex upper and lower motor mounts
Spec Stage 1 clutch
Helix Engine Damper
Others:
Suspension:
H-sport springs
Koni Yellows
18mm HandR rear sway
H-sport rear control arms
Powerflex front control arm bushings
fresh ball joints!!
Alignment:
Front camber (-0.5 on driver) (-0.3 on passenger)
Front toe(1/16 toe out)
Rear camber (-1.4)
Rear toe (1/16 toe in)
Brakes:
Powerslot front rotors
Mintex pads all around
Brake Calipers painted red
Wheels and tires:
Black with red lip (Rota Group N's) (12lbs) (15x6.5)
205/50/15 Bfgoodrich G-Force Sports
Exterior:
Mini Cooper S front bumper
Tinted windows (35% on front) (15% on rear)
(Blacked out
Head light rings
Rear boot handle
MINI Cooper S gas cap
Lower front grill
Tailights
Side markers
Side grill markers
Stock tow hook painted red
Racing strips on bonnet and boot
Debaged rear
Yellow tint on front turn signals and reverse light
Shorty anttena
Interior:
Red shift boot
MINI Cooper S shift ****
Red tape around tac
Audio:
Pioneer deck
Pioneer 6 1/2 front speakers
stock tweeters and rear 6X9 speakers
HOW MUCH HORSEPOWER AND TORQUE YOU GUYS THINK I AM PUSHNG TO THE WHEELS WITH THE MODS I HAVE DONE?
Koni yellows, H-sport springs, H-sport rear control arms, powerflex front control arm bushings, 15x6.5 Rota group N's (12 lbs), 205/50/15 Bfgoodrich G-force Sport tires, Magnaflow cat-back, intake filter, Spec stage 1 clutch, Powerflex upper and lower motor mounts
MUCH MORE!!
Engine:
Magnaflow car-back
Spec Stage 1 clutch
Helix Engine Damper
Others:
Suspension:
H-sport springs
Koni Yellows
fresh ball joints!!
Alignment:
Rear camber (-1.4)
Brakes:
Wheels and tires:
Exterior:
(Blacked out
Head light rings
Rear boot handle
Lower front grill
Tailights
Side markers
Side grill markers
Debaged rear
Shorty anttena
Interior:
Red shift boot
Red tape around tac
Audio:
Pioneer deck
MUCH MORE!!
115bhp and 110tq??????
haha, j/k but problly not a whole lot more than stock. im sure theres a noticable amount of throttle response but theres little to be gained with only a replacment filter and a catback but your car looks and sounds good. you also have a few parts on yours that i will be tossing at mine before next spring. so i say, nice work!
There is a thread elsewhere on this forum about GIAC for the MC. Check back through last spring. Speaking from experience, with your Magnaflow an ECU remap will get you over 120 HP at the wheels.
post some pics of your car in your gallery on on here. its looks pretty sweet but its kinda hard to see details when its flying by.
it does sound nice ive been looking for an exhaust for mine but i just didnt want to spend the money and not know what it would sound like.
Looks great. Nice mod choices.
I would have to recommend the K&N typhoon for sound, tho. The sound is crazy. You'd love it. Subtle then, WOT, Bwaaa. . . . You may like it better over the stock box with a panel filter. But, I do hear it can get drowned out by a louder exhaust. (And be sure to clean and re-oil every 8-12 months, and don't overoil, of course.)
As far as heads go, from what I've researched, do a port & polish on a stock cooper S head (stronger valves, everything else is the same) and keep the stock valve size, and upgrade the cam (schrick or that new one coming out. . name?). Larger valves aren't as advantageous an a Cooper. Some would say they are, but if the point was "***** out power" we wouldn't have coopers. Plus, gas mi. would be in the crapper. After that, maybe an extrude honed intake manifold and exhaust header matched up the the ports, ECU flash to match the mods and you'd be good to go. Haven't heard wnything bad about any ECU tune: GIAC, MTH, Unichip, etc. everyone's happy.
Anyway, great work.
Anyway, great work.
Well right now I have a generic intake filter. I noticed that the car sounds a lot better and it feels slightly quicker mostly in the higher rpms. I go still have my stock air box with a True Flow panel filter in it. With the panel filter the car seems a little smoother with a less peaker powerband around 4,000 rpms. With the generic intake filter the car is a little rougher and lounder with a peaker powerband around 4,000 rpms. Why is this?
well, until you get moving your sucking hot air... so probly about the time you get up to speed and start moving the air under the bonnet (in 1st gear) your going to start hitting our power band at 4k or so. and then once you shift to second the ride is just about over. but im sure at speed your getting more air than you would with the stock box.
Keep it up
