Hamann PG4 wheel and tire combo...
Old Sep 29, 2007 | 10:13 PM
Mozza's Avatar
Mozza
Hey folks, I'm shopping for wheels for my future Mini and have my heart set on a set of Hamann PG4's. While doing some research online I came across this article on tuningmag.net http://www.tuningmag.net/?name=mini-...-tuning-hamann
This sentence immediately jumped out at me, "The rims are booted also in a big style. HM4 needs 215/40 17“ tires. The 18“ PG4 tires are booted into the 215/35 front and 225/35 rear tires. And the Anniversary I model has same tires as the HM4."
Can someone shed some light on this? Is changing the rear tire size just something Hamman did or is it an actual necessity for PG4's as the back wheels are a different size? What I'm basically trying to find out is if I'll be ok if I go with 215/35/18's all round because having two different tires sizes on the car causes too many problems with spare issues etc.
Thanks in advance any help is appreciated.
Old Sep 30, 2007 | 12:14 AM
jerjer's Avatar
jerjer
i think what hamann did is more cosmetic issue other than a performance decision. making the back tires fatter just makes a car so much more aggressive in appearance (IMO!)
but since the mini is a FWD, having fatter tires in the front and narrower tires at the back will enhance the performance in more traction off the line, better turn in performance..etc
but either way, fat tires are always hot!
Old Sep 30, 2007 | 06:37 AM
Mozza's Avatar
Mozza
Thanks jerjer, so basically I'll be ok if I go with 215/35/18's all round then?
Old Oct 1, 2007 | 03:12 AM
jerjer's Avatar
jerjer
yea, 215/35/18 would be a fair choice, cause there is alot more option to choose from. the 225/35/18 only have a few to pick from, i only rmb parada spec2 being 1 of them.
but i think 215/35/18 would look great with the rims either way!
hope that helps, and enjoy those heavily priced work of art!
Old Oct 1, 2007 | 02:21 PM
Mozza's Avatar
Mozza
Will do jerjer thanks a lot. I've decided to go with a set of BFGoodrich g-Force KDW's with the new tread. You should check them out they're a stunning tire.
Old Oct 1, 2007 | 02:26 PM
sandtoast500's Avatar
sandtoast500
I think that the PG4s for the MINI comes in 18x8 all around. I know HM4s are 17x8 all around. . . For tires, wait til Minihune chimes in. . . I hear 215/35s are pretty small sidewalls. maybe 205/40 instead. Vicious circle: expensive large wheels: small tires: bent wheel: even more expensive. Personally I like the HM4 better.
pre shrunk
Aug 18, 2015 11:09 AM
sabjcw
Aug 14, 2015 07:40 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
nomar116
Aug 9, 2015 09:42 AM
