R50/53 Help replacing window motor DIY
Old Sep 29, 2007 | 06:13 PM
03StuckInAustin's Avatar
03StuckInAustin
The driver side window on my '03 mini has failed. My car is no longer in warranty and the dealership has offered to pay half (becuase my sunroof motor failed last week in the OPEN position, which they replaced at no charge) if I was willing to cover the other half. They quoted my half would be $200. oouch! After reading about window failures on this forum and others, I've come to the conclusion... my passenger window will fail next.
Can anybody provide instructions on how to replace the motors? This seems like a great do it yourself project that will save my and others bundles of cash down the road.
Old Oct 2, 2007 | 06:07 PM
healey67's Avatar
healey67
Unfortunately you should find someone who knows what they are doing with this. If you should pull the motor away from the regulator with the cable spool attached to the motor, then you are buying a window regulator too. If you try yourself. make sure you pry the motor away from the regulator with care. 200 can turn to 300 faster than you think....
Old Oct 2, 2007 | 07:53 PM
03StuckInAustin
Thanks for the reply. I was hoping for something a bit more positive. Are you a mini technician?
Old Oct 3, 2007 | 05:22 AM
ProfessorDave's Avatar
ProfessorDave
Stuck,
Do a search on "window motor" and you will find some very useful tips on replacing this part. The Bentley Manual is also helpful, with some good diagrams. Like Healey, the Bentley Manual cautions against allowing the regulator to separate from the motor.
I'm assuming you've tried the "bang the door above the speaker" trick, right?
Old Oct 3, 2007 | 10:43 AM
goldcountrymini's Avatar
goldcountrymini
I have the same problem. It's about time for me to replace my motors as well... I'll have to search on NAM too I guess. I thought there was a DIY thread on here for that? I recall seeing that somewhere...
Cereall
Sep 5, 2019 06:05 PM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
Dec 23, 2015 10:36 AM
thebordella
Aug 31, 2015 01:37 PM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
