Clutch pedal...
Old Sep 26, 2007 | 10:17 AM
buggin83's Avatar
buggin83
Clutch pedal...
okay i am sort of new here, i have been a VW driver since i was sixteen and then just got a WRX last year. in short just wasnt me and decided i am getting what i have wanted since, well since the concept was first shown... a Mini.
so here is were my question begins, i am looking at a 2004 mini and i am told the clutch was just replaced by a certified Mini Mechanic. although when i test drove it the the clutch pedal felt real slow, sort of like it needed greased or something, and then when you popped the hood you could hear a noise when the clutch pedal was pressed down (the sound was a low sound, if that helps). just wondering if anyone could help out with any ideas or suggestions.
Thank you in advance,
Old Sep 26, 2007 | 10:52 AM
jakay11's Avatar
jakay11
I would not buy that particular Mini... I'd keep looking, as it doesn't seem that the tech fixed the issue.
Old Sep 26, 2007 | 10:55 AM
adam76's Avatar
adam76
Just order a new one, unless you specifically want the 1st gen styling. Not that big a price difference.
Old Sep 26, 2007 | 11:11 AM
Speedwing's Avatar
Speedwing
https://www.northamericanmotoring.co...ad.php?t=96588
This is a fantastic thread with instructions on how to replace a clutch. Reading towards the end you will find a lot of extra stuff done besides the major clutch components.
I'd say the noise is the throwout bearing against the pressure plate fingers. The clutch and the brakes share the same hydraulic resevoir. The clutch has a master and slave cylinder and might need re-bleeding. Improper lubrication of replacement parts might also contribute to slowness.
I'd want to see a list of the parts that were replaced!!!!!
Old Oct 21, 2007 | 03:02 PM
Raoul5050's Avatar
Raoul5050
Anyone know of the best place to take a 2002 Mini for repair in S.F. area? Dealer or private.
drrigg
May 27, 2022 03:31 AM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
