Clutch problem: vibration/whirring when pedal is depressed?
Old Sep 25, 2007 | 05:39 AM
GrFa's Avatar
GrFa
Well on my new to me 02 Cooper, 5 speed, 12k miles, I noticed a very strange whirring noise when the clutch is depressed. With the hood up it seems to be coming from behind the engine. My father thought it sounded like a whoosing noise. I am thinking it is either the slave or the release/throw out bearing. The dealership suggested the slave based on those symptoms.
Also, when you are pressing the pedal you can feel a vibration through your foot, almost feels like grinding. You don't even need to start depressing the clutch pedal, just some pressure on it and you can feel it. Any ideas?
Old Sep 25, 2007 | 05:48 AM
defylogik's Avatar
defylogik
i dont know the intricacies(sp) of the cooper transmission but from experience on other cars may be a throw out bearing.
Old Sep 25, 2007 | 06:25 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
My cooper s had the throw out bearing and the slave cylinder both fail. If it is begining then take it to the dealer IMMEDIATELY. I waited and 3 DAYS after I noticed this my car was undrivable. I had to trailer my car from Defiance, Ohio to Columbus, a 2 1/2 hour drive! These two parts cost under $200.00, but installation kills you. But if you wait you risk footing a big bill. The dealer charged me, NOT UNDER WARRANTY(some dealers suck), $1,200.00 and that is half the cost, the dealer picked up the other half.
Old Sep 25, 2007 | 06:26 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Oh, the dealer had to replace my slave cylinder, throw out bearing, clutch disk, pressure plate, and input shaft.
Old Oct 5, 2007 | 03:01 AM
harhoosh's Avatar
harhoosh
I had the same problem exactly.. once i finish the installation of the clutch kit and the slave cylinder.. i notice that there is a "gshshsh" sound once i shift from my 1gear to the 2gear :S
I toke it back to the garage.. they told me its the syncro's are gone.. i toke it to the other garage. he said you have to replace your transmission.
anyone with the same problem ?
Old Oct 5, 2007 | 03:31 AM
chadtoolio's Avatar
chadtoolio
I think that the determining factor is does the whoosh or what ever happening when the clutch pedal is down and held....if so, it would indicate throw out bearing problem. If the noise only happens while the clutch is *being* pressed, then I would look harder at the slave cylinder.
Old Oct 6, 2007 | 02:31 AM
harhoosh's Avatar
harhoosh
I changed the slave Cylinder. But this problem happens once i shift the gear from the first gear into the 2gear only .. so thoughts ? befor i change my transmission
Old Oct 6, 2007 | 02:20 PM
GrFa's Avatar
GrFa
Yep I am pretty sure its a throwout bearing in my case. It hasn't gotten too loud yet, but I am not driving the car regularly anymore either. I really need to get it fixed.
drrigg
May 27, 2022 03:31 AM
scfiveo
Sep 27, 2019 02:27 PM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Sep 28, 2015 09:13 AM
