R56 DENT - Rear qtr question
Old Sep 24, 2007 | 06:55 AM
SuwaneeM3's Avatar
SuwaneeM3
AHHH! I'm an idiot! I was parked too close to our X5 and the rear door (which is big and heavy and is spring loaded open)... pounded the crap out of my rear qtr panel. No paint was removed but like a qtr size dent right snap in the middle of the fender.
I already have an appt at dent wizard... but instead of removing the entire rear upholstry and seats in order to get to the side panel... can you access the fender thru the rear tail light assembly?
Old Sep 24, 2007 | 06:59 AM
korby's Avatar
korby
They can go through the wheelwell , It will have to be jacked up .
Old Sep 24, 2007 | 07:08 AM
clubspec330i's Avatar
clubspec330i
Post some pictures..it will be good for future reference..
I hope you fix the dent.
On the side note, weren't you on roadfly.com, too? I remember reading your M3 post back in '02 or '03 something like that.
Old Sep 24, 2007 | 07:10 AM
Kasey's Avatar
Kasey
I had a dent on my rear quarter panel and the PDR guy was able to remove it through the access panel in the hatch.
Old Sep 24, 2007 | 07:31 AM
ZIPPYJR's Avatar
ZIPPYJR
They won't take apart the car, they use suction cups to pull the dent out.
Good luck.
Old Sep 24, 2007 | 07:32 AM
SuwaneeM3's Avatar
SuwaneeM3
I'll post before and after. Sounds like i wont have to remove the interior.
I kept my same name as on Roadfly. I've been a member there for 7 years. Sold the M3 a month ago (weep weep).
-s
Old Sep 24, 2007 | 07:33 AM
Kasey's Avatar
Kasey
Good luck.
The guy who fixed mine pushed it out from the inside by running some weird rods through the access panel. I've seen the suction cups used, as well.
Old Sep 24, 2007 | 07:42 AM
SuwaneeM3's Avatar
SuwaneeM3
thank you so much for all the quick replies. THis has been burning me up all day yesterday. I changed my appt to this afternoon now that I dont have to go pull the interior out.
Old Sep 24, 2007 | 11:01 AM
SuwaneeM3's Avatar
SuwaneeM3
UPDATE: I just went in... and I will have to remove the interior. Oh well. PICS tomorrow.
-s
Old Sep 24, 2007 | 11:54 AM
Kasey's Avatar
Kasey
-s
I really want to see where this dent is. Looking forward to pictures.
Sorry you are having so many problems, dents and MINI's should never go together in the same sentence.
Old Sep 24, 2007 | 04:00 PM
SuwaneeM3's Avatar
SuwaneeM3
It's right behind the door handle... directly behind the speaker (which is good luck if there is luck to have in this mess).
I have a before pic... ill wait until tomorrow to show the two. As well... might as well just replace the 6x9's since Im already in there.
I hate having my garage full of 2 week old interior. Not only is it frustrating that I did this.. .but I may lose that "new car smell". And of course... i scratched some of the interior pieces trying to get the blade under the pop rivets. That's not so bad though... it will wear anyway.
Old Sep 25, 2007 | 01:03 PM
SuwaneeM3's Avatar
SuwaneeM3
UPDATE
For those who have been following this... I went to Dent Wizard to pull this out. I had to pull the entire interior in order to get behind the 6x9. While I was in there, I replaced the 6x9's with Infinity References. I have the hifi audio, so I had to remove the tweeters built into the grille and flush cut the mounts off so they wouldnt interfere with the Infinitys
Dent Wizard charged $130... and did an excellent job. Although I know where the impact is... no one else can find it. So i'd say it is 99.8% back to perfect. Thank the Lord.
Attached Thumbnails DENT - Rear qtr question-dent.jpg   DENT - Rear qtr question-afterdent.jpg
Old Sep 25, 2007 | 01:14 PM
jrammon's Avatar
jrammon
Looks great! Glad it all worked out well.
Old Sep 25, 2007 | 08:50 PM
Kasey's Avatar
Kasey
Looks great! That was definitely a lot farther forward than mine, must be why they had to take it apart.
Glad it worked out, big sigh of relief, huh?
Old Sep 25, 2007 | 08:59 PM
SuwaneeM3's Avatar
SuwaneeM3
YEA! I wouldnt let them touch it though... i brought it home and pulled everything off. Just been burned too many times before with people breaking stuff. Im real happy with it... and now really careful of doors. The metal seems a little thin.
Old Sep 25, 2007 | 10:51 PM
Robin Casady's Avatar
Robin Casady
Glad it worked out.
Out of curiosity, why Infinity Reference instead of Kappas?
Old Sep 26, 2007 | 11:40 AM
SuwaneeM3's Avatar
SuwaneeM3
Originally Posted by Robin Casady
Glad it worked out.
No reason other than they were in stock, new models, and on sale. They're also 2.6 ohm nominal... which is what I measured on the stock hifi 6x9s that I removed.
They are somewhat better than the stock units... but I'm not blown away. It's not like all of a sudden you have thumping tight bass where you didnt have it before. They go a little louder than stock and seem a little crisper.
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
jeffbeckhudd
Aug 29, 2015 09:11 PM
Minibeagle
Aug 13, 2015 10:00 AM
ludedude
Aug 10, 2015 07:16 PM
