Navigation & Audio Radio Noise!!!!
Old Sep 21, 2007 | 06:46 AM
MCS02's Avatar
MCS02
MINI Alliance Ambassador
Radio Noise!!!!
I have a 02 mini S with the stock radio. It had a 6cd changer I removed to add an iPod integration unit. I use to get good AM reception but it slowly has gotten worse, this started before I installed the Dice unit. It has reached the point that AM is unusable and I am starting to get noise through my Dice unit when my iPod is plugged in.
The Mini has 50,000 miles on it I tried new plugs but this did not help. I have Nology Hot Wires - High Perf. Plug Wires that are about 4 years old I have tried grounding then in a new spot with no change.
If any one can help I sure would appreciate it.
P.S. my wife’s Sequoia has a hum all the time FM and AM and I have not touched it, maybe its me?
Old Sep 21, 2007 | 07:04 AM
naffets's Avatar
naffets
Interesting that you have the nology wires. I just put some on about 1k miles ago and have now noticed that my AM reception has gone pooey as well during that time.
I didn't associate the two items being related until now that i've read your comments.
I did change where I was grounding the nology wires (to the bottom ic mounts) and checked to make sure there was continuity to the actual nology grounding wire and the car grounding wire (left side of engine bay).
Has anyone else with nology wires expierence the same problem?
Old Sep 21, 2007 | 08:42 AM
Jahmills's Avatar
Jahmills
Does the hum change pitch with engine speed? If so then it could be your alternator, if not then try changing your spark plug wires back to OEM type.
Old Sep 21, 2007 | 09:46 AM
MCS02's Avatar
MCS02
Yes the hum does change pitch with engine speed and goes away when the motor is switched off. If it’s the alternator can I fix it or does it need to be replacing?
Thanks.
lweaver
Sep 17, 2024 08:22 AM
Supertractor3
Apr 7, 2017 11:16 AM
67morris
Dec 1, 2015 12:53 PM
paul7878
Sep 14, 2015 07:44 AM
quality_sound
Sep 12, 2015 05:55 PM
