02 Sensors on ebay
Old Sep 14, 2007 | 05:23 PM
twonz1's Avatar
twonz1
02 Sensors on ebay
I have a bad 02 sensor (not sure which one) and looking for a little advice. My SES light keeps going on and off and my obll reader says that it's an 02 sensor fault (0130). My car is out of warranty and I checked a parts store for the sensor and he said his cost was $144.00. I didn't even ask what my cost would be before I checked ebay. I found one on ebay for $15.97 plus shipping. The description says that it's a universal sensor for 02-06. Has anyone had any experience with this kind of replacement or is it just too good to be true. Thanks for any response.
Old Sep 14, 2007 | 08:22 PM
rl.48.mini's Avatar
rl.48.mini
to answer your question first, I haven't tried the ebay item so I don't know what kind of plugs come with them or if you have to reuse your existing one. I just replaced my post-cat O2 sensor with one I purchased from Atlantic British. The plug in is an exact match for the original, the wire was the correct length and it cost about $75. Non-original but it works and fit perfectly.
Old Sep 15, 2007 | 08:01 AM
techtipz's Avatar
techtipz
Replace the 02 sensor. Than clear the fault. The oxygen sensor is your problem with that fault.
Old Sep 16, 2007 | 11:59 AM
pmfranke's Avatar
pmfranke
the dealer wanted $285. changing the plug is not the best idea(to make the universal one work).02 sensors are very sensitive ,soldering the wires might change the resistance.Go for the cheapest one that is a direct replacement
Old Sep 16, 2007 | 03:20 PM
joey1320's Avatar
joey1320
p0130 is your primary o2 sensor, before the cat.
i would buy a factory one and replace it myself. all you need is a 22mm wrench and then have the code cleared.
shorenetworks
Nov 4, 2019 06:18 PM
CRC
Dec 26, 2015 11:30 AM
renchjeep
Sep 6, 2015 01:54 PM
eliseo1981
Sep 4, 2015 02:33 PM
Ntety
Sep 2, 2015 08:39 PM
