Navigation & Audio Auxiliary sound not working on passenger side
Old Sep 11, 2007 | 03:10 PM
femmenue's Avatar
femmenue
Hello,
I just installed the auxiliary plug for the mini cooper, it was increidbly easy and just popped right in, but today I noticed theres no sound coming from the passenger side speakers. Its not the speakers because they work with the radio and cds just not on aux. should I unplug and replug it in or what else? Thanks!
Old Sep 11, 2007 | 04:09 PM
rkw's Avatar
rkw
Unplug/replug is one thing to try, but also make sure that your cable is stereo, not mono. Check by looking at the plug. I posted this a while back:
A stereo plug has 3 segments.
A mono plug only has two segments.
Old Sep 11, 2007 | 04:41 PM
femmenue's Avatar
femmenue
So if its a mono plug then it only plays from one speaker and not two? Is that the only difference?
Old Sep 11, 2007 | 06:32 PM
Edge's Avatar
Edge
AdMINIstrator
A mono cable should produce the same sound from both speakers, it should not cause no sound on one side.
I suspect that the problem is most likely either the cable is not properly connected, it's a faulty cable, or that the Aux Input needs to be checked right up to the head unit. It's possible one of the wires came loose from the connector.
Old Sep 11, 2007 | 09:37 PM
rkw's Avatar
rkw
A mono cable into stereo jacks produces sound only on the left side.
Look at the diagrams of the plugs. The right side becomes grounded.
Old Sep 11, 2007 | 10:13 PM
Edge's Avatar
Edge
AdMINIstrator
Oops, you're right. Never mind.
I have seen mono-to-stereo wires that do achieve same audio on both channels though, and that's probably why I was confused.
Kimolaoha
Jul 5, 2023 01:04 PM
boostedhaze
Jan 2, 2018 07:26 PM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
quality_sound
Aug 7, 2015 09:36 AM
