Navigation & Audio Line Out for Rear Wire Harness?
Old Sep 4, 2007 | 05:28 PM
FortyTwo's Avatar
FortyTwo
I found this wiring harness in the rear passenger well that I believe is for the factory amp. I have the standard stereo in the Cooper S, and would like to add an amp via Line out converter. Can someone help me identify the wiring if I am correct?
Also, I have a Basslink2 that accept speaker level or line level inputs. would one be preferable to the other? The speaker level input to the amp looks like a square, where can I find a harness to adapt if the is the appropriate route? Thanks!
Old Sep 4, 2007 | 05:47 PM
FugitiveAI's Avatar
FugitiveAI
There are a few detailed threads on this upgrade you'll want to find. What I do know off the top of my head is the head unit does not have line outs. That harness is speaker level. when the hifi option is selected, the boost amp they put in that compartment you refer to has speaker level inputs for that harness, which it converts to line level and reamplifies.
Old Sep 4, 2007 | 06:14 PM
FortyTwo's Avatar
FortyTwo
I've read through every thread in the 2nd gen Audio forums, but may have missed diagrams of the amp wiring harness. If you happen to know where I missed it, can you please post a link?
I knew that the HU did not have line outs, but I thought it would be far easier to tap wires already in the right location than to run wire behind the dash. On my last car, I rewired the factory harness to run through a LOC and rna RCA to the back of the car. I am no expert, and have only run RCA in the past, so I don't know if there are advantages to running speaker level input to the amp.
Thanks for the response!
Old Sep 4, 2007 | 06:30 PM
Robin Casady's Avatar
Robin Casady
This isn't a chart, but a list of wire colors might be useful:
https://www.northamericanmotoring.co...d.php?t=105832
Old Sep 6, 2007 | 08:16 AM
Birdman's Avatar
Birdman
I'm REALLY suprised somebody hasn't made a "T" wire harness connector for the factory amp connector???
Does anyone know what brand/type connector is back there? It would be SO EASY for somebody to make a T connector. We could then simply unplug the built in amp, plug in the T, plug the amp back into the T, and now have documented wires at hand to use (+/- each speaker and +/-12v switched Power).
Why hasn't one of the vendors done that??
Old Sep 6, 2007 | 11:03 AM
FortyTwo's Avatar
FortyTwo
This is exactly what I'm trying to do!
I'm no expert on it though, and was hoping to get some insight from the community at large. Any help on finding the male and female connectors would be awesome, too. I'm checking McMaster-Carr now, and I'll try RealOEM; any other suggestions?
Old Sep 6, 2007 | 12:41 PM
MotorMouth's Avatar
MotorMouth
Those wires are not for the hifi amp. First they are on the wrong side. Second if you don't have the HiFi system the amp and wires just won't be present.
Old Sep 6, 2007 | 12:46 PM
Birdman's Avatar
Birdman
Forty,
I just realized, you are on the WRONG SIDE!! The amp and it's connector are on the DRIVERS SIDE. Not sure what that white connecor is, but my hifi amp is on the passenger side. Check out this thread, around page 2 has all the pinouts and wire colors for the amp connector and what each is. https://www.northamericanmotoring.co...t=95211&page=2
Here is some of the info/links compiled:
Amp Wiring
Amp Power Wiring
Connector Pinout
Amp Location
Translations from diagrams:
RT = Rot = Red
GE = Gelb = Yellow
GN = Grün = Green
BL = Blau = Blue
VI = Violet = Purple
GR = Grau = Grey
BR = Braun = Brown
WS = Weiss = White
SW = Schwarz = Black
xx/yy = xx wire's main color with yy stripe
VL = Vor Links (Front Left)
VR= Vor Rechts (Front Right)
HL = Hinter Links (Rear Left)
HR = Hinter Rechts (Rear Right)
The + and - are self explanatory.
No Amp (no hifi):
Radio Wiring (no amp)
Radio Power, Antenna, CAN, MOST
Connector Pinout
Power Input
(Pin - Wire Color - Function)
5 - Red/Gray (This is a 20A circuit that should provide power to a modest aftermarket amp without needing to run a seperate lead)
10 - Power Antenna lead (to turn on your aftermarket amp. I'll check the voltage/operation when I can).
26 - Brown (Ground)
18 - Orange/Green (No idea, but it causes me concern as it's labeled "K_CAN_L")
19 - Green (No idea, but also causes me concern as it's labeled "K_CAN_H")
Audio Input (Speaker level input from headunit)
(Pin - WireColor - Polarity)
Front Left
38 - Black/Red (+)
30 - Black/Purple (-)
Front Right
9 - Yellow/Brown (+)
17 - Yellow/Black (-)
Rear Left
37 - Blue/Brown (+)
29 - Blue/Black (-)
Rear Right
8 - Brown/Orange (+)
16 - Yellow/Red (-)
Output (Speakers)
Front Left Woofer (6 1/2")
41 - Black/Red (+)
42 - Black/Purple (-)
Front Right Woofer (6 1/2")
39 - Yellow/Purple (+)
40 - Yellow/Gray (-)
Front Left Mid/Tweet*
33 - Blue/White (+)
34 - Blue/Brown (-)
*Need help here. The schematic is confusing, but I believe this lead goes to the 3 1/2" mid, with the tweeter slaved off this lead with a capacitor. DyeLooper noted the colors to his (HIFI) mid, and MotorMouth noted the tweeter has a cap. The colors for the tweeter wires should be Brown/Orange (+) and Blue/Red (-)
Front Right Mid/Tweet*
11 - Blue/Black (+)
12 - Blue/Brown (-)
*Need help here as well, as noted above. Colors for the tweet should be Brown/Orange (+) and Yellow/Black (-).
Rear Left Woofer (6x9)
4 - Red/White (+)
3 - Brown (-)
Rear Right Woofer (6x9)
23 - Red/White (+)
22 - Brown/White (-)
Rear Left Tweeter*
31 - Yellow/Black (+)
32 - Yellow/Brown (-)
*There are a couple of manufacturers of component 6x9's, but 5x7 or 6x8 components are more common. These leads aren't necessary if you use a coax or triax 6x9.
Rear Right Tweeter*
13 - Yellow (+)
21 - Brown (-)
*Same note as Rear Left Tweeter.
Old Sep 6, 2007 | 12:48 PM
Birdman's Avatar
Birdman
Yes they are, I thought in that thread I just posted they confirmed non-hifi folks have the speaker leads there, just not the amp itself....??
Anywhoozle, I have the hifi, and sombody needs to make me a T connector.
Old Sep 6, 2007 | 01:30 PM
MotorMouth's Avatar
MotorMouth
Nope, no wires. Even the carpeted side piece is different if you have the hifi or not. If you don't have the hifi the access hole is both inset several inches and it's much smaller than if you have the hifi.
Old Sep 6, 2007 | 05:04 PM
FortyTwo's Avatar
FortyTwo
Thanks for the info! Any idea what those wires are for then?
I think I might be better off tapping the 2 rear speakers for a speaker level input to the amp, if I don't have easy access to a separate wire harness.
Old Sep 6, 2007 | 05:21 PM
DyeLooper's Avatar
DyeLooper
towing connections?
Old Sep 6, 2007 | 05:37 PM
kfisto's Avatar
kfisto
What about part of the Sirius or HD Radio options? I vaguely remember reading or seeing a picture denoting that the Sirius or HD radio stuff goes on the passenger side.
Old Sep 6, 2007 | 08:08 PM
FortyTwo's Avatar
FortyTwo
I have the Sirius option in my car, the one from the pictures at the top...
Old Sep 6, 2007 | 09:10 PM
ScottRiqui's Avatar
ScottRiqui
Birdman,
Great post with the wiring diagrams/pinouts/colour codes. Do you happen to know if there's a similar reference for the first-generation cars?
I'm basically trying to find out the colours of the eight speaker wires coming out of the "Boost" head unit, and I'd also like to find out if those colours are the same where the harness enters the Harman/Kardon amp.
Old Sep 6, 2007 | 09:22 PM
kfisto's Avatar
kfisto
Doh! Um... factory HD Radio antenna/tuner?
hehe, I'm not an expert, but I did sleep in a Holiday Inn Express last night (not really...)! hehe
Old Sep 7, 2007 | 09:02 AM
Birdman's Avatar
Birdman
Motor, wow, interesting they only run the wires for the hifi. They really do customize each car huh?
Scott,
Thanks, but I cna't take credit for any of that, I just copied and consolidated it from several different posts in that thread I posted the link to. Sorry, I know nothing about the 1st gen mini's. Isn't the R56 the first MINI made???
Originally Posted by ScottRiqui
Birdman,
Old Sep 9, 2007 | 12:45 PM
FortyTwo's Avatar
FortyTwo
Thanks a ton for the information, it really came in handy.
The was no amp wiring in my MINI after all. I went ahead and tapped the harnesses for the 6x9's to run speaker level inputs to the Basslink. I was disappointed to see the left rear speaker had a hole in it! It'll give me an excuse to buy new ones, I guess. Install was fun!
Wohnson89
Jun 10, 2020 04:53 AM
W0TM8
Dec 19, 2019 07:50 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
PSIChocolate
Aug 13, 2015 12:46 PM
DWooderson
Aug 10, 2015 09:12 AM
