Suspension Rear adjustable coilover setting????
Old Aug 31, 2007 | 03:32 AM
JCW2006AUS's Avatar
JCW2006AUS
HI,
How does everyone adjust the rear coilover damper settings, as the adjustment is in the chasis rail
Cheers.....
Old Aug 31, 2007 | 09:06 AM
90STX's Avatar
90STX
If you got SPAX, Bilstein or a few others, it's easy because there is a **** at the bottom of the damper.
Assuming you have Konis or one of the other designs with the adjustment at the top of the damper shaft, you can either drill a hole so you can access them from the boot, or just remove the two capscrews at the top of the strut and lower it enough to make the adjustment. It's easier than it sounds, but not nearly as friendly as having one of the setups with a bottom adjustment ****.
Scott
90SM
Old Sep 3, 2007 | 06:08 AM
JCW2006AUS's Avatar
JCW2006AUS
Cheers, actually I have the TEINS with EDFC but was curious as the TEINS have top adjustment but with EDFC it dosent matter!
Thanks.....
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
