Suspension IE Ireland Engineering Fixed camber plates Question
Old Aug 22, 2007 | 07:49 AM
jymontoya's Avatar
jymontoya
So, I have about 5mm of clearance between my front struts, and my tires. If I install the fixed IE camber plates, will this distance increase, decrease, or stay the same.
My thought is that because the top is moving toward the engine, then the distance would increase, but I just want to be sure before I buy them, AGAIN.
Old Aug 22, 2007 | 08:37 AM
k-huevo's Avatar
k-huevo
There will be no change with camber plates. That gap is determined by tire width and wheel offset.
Old Aug 22, 2007 | 10:30 AM
03Indigo's Avatar
03Indigo
User Title's are Silly
meaning that the angle of the tire and the strut remains constant in relation to each other. As you move the strut in with the fixed camber plate, the tire/wheel will move the same amount of deflection. So like k-huevo stated, no change.
Old Aug 22, 2007 | 11:19 AM
jymontoya's Avatar
jymontoya
BEAUTIFUL! THANKS!
W0TM8
Dec 19, 2019 07:50 AM
sabjcw
Aug 14, 2015 07:40 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
