Tensioner replacement without tool?
Old Aug 20, 2007 | 11:22 AM
Aeromax's Avatar
Aeromax
Does anyone have any suggestions for swapping the tensioner out, when one does not own the special tool?
Old Aug 20, 2007 | 12:37 PM
ignote's Avatar
ignote
Do you mean without the tensioner tool?
Old Aug 20, 2007 | 03:10 PM
Aeromax's Avatar
Aeromax
Yup.
Old Aug 20, 2007 | 05:07 PM
herbie hind's Avatar
herbie hind
you put a 16mm socket on the main pivot bolt up front. this is used to pry on. there are two holes on the arm surrounding the tensioner pulley; put a small bolt or pin in one. i used a pin from a go-kart linc. use a large pry bar to pry up on the small pin,using the 16mm as a pivot. while the slider is exposing two holes above the spring place a leather awl or a skinney punch of some kind in the lowest hole. this will hold it . now pull the belt .
Old Aug 21, 2007 | 04:53 AM
ignote's Avatar
ignote
Yep that will work. My variation was I used a 7/32 allen wrench in the tensioner hole, a long piece of re-bar for the pry bar, and instead of the 16mm as a pivot I used a large crescent wrench placed across the frame and engine block. Pull back real hard and have a helper put another pin or allen wrench in the second slider hole to hold the tension.
Old Aug 21, 2007 | 06:13 AM
Aeromax's Avatar
Aeromax
Wow, glad to hear that works. I'd have not thought of that myself unfortunately..
minipopkart
Aug 13, 2015 05:22 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
