Control Arm Snapped in Two
Old Aug 19, 2007 | 12:10 AM
Penelope_the_MINI's Avatar
Penelope_the_MINI
So I'm on my way back to my home in Ventura from Burbank Airport today when, all of a sudden, in the fast lane, the back of my car goes completely sidways. I gained control without hitting anything thankfully and quickly got over to the shoulder. I got out and took a look to see what had happened. I'm expecting to see a blown tire or something, but instead, my left rear tire was at about a 45 degree angle. I looked underneath the car and saw a clean break right in the middle of the contol arm . I probably scared the crap out of the guy behind me when that thing snapped. I totally lost control there for a moment. I'm glad I'm not dead after that happening while going at "Freeway Speeds" in the fast lane of the 101.
The good news out of all of this is that I still have 2300 miles on the warranty so the roadside assistance and the repairs will be free. And, the broken control arm was the only thing wrong with it; from what I could see. Also, this 'incident' happened, literally, right in front of a MINI dealership, so the tow truck driver just got off at the next exit and we were there .
So, I'd just like to advise anyone with a 2003 or older MINI: CHECK YOUR CONTROL ARMS! they are made of aluminum and look like a very flimsy design. You should check for any hairline fractures or any signs of stress and fatigue. Or better yet, replace them with some solid aftermarket ones.
Okay, thanks for letting me get that off of my chest. This fix should take the dealer no more than a couple of hours too fix on Monday. I'll let you know how it went.
Old Aug 19, 2007 | 01:22 AM
MINICORSA's Avatar
MINICORSA
I had the same issue but my upper one bent then snaped within a week after a bad dip on the track. prolly cuz I had aftermarket lower arms. It is a very weak part of the car and extreamly expensive to replace with the factory piece. It's much cheaper to go aftermarket in this case. Glad to hear nothing happened to you. lucky one you are. Mine gradually went out after a bad track day. FYI my car has 34000 miles and no more then 5 hours of track time i.e. 4-5 track days.
Old Aug 19, 2007 | 05:03 AM
cristo's Avatar
cristo
Alliance Member
Actually, the oem rear control arms are stamped mild steel, but yes, not the strongest piece on the car.
Old Aug 19, 2007 | 09:50 AM
Penelope_the_MINI
My mistake, thanks for clarifying. But yeah, very thin and flimsy looking none the less. I guess the Very clean break suggested it was aluminum. All of the road dirt and grime made it hard to identify properly (and I didn't really have a magnet handy)
I wish I had a good picture of it. My wheel has so much of an angle on it, it looks like I'm about to do some serious drifting.
Old Aug 19, 2007 | 11:12 AM
Crashton's Avatar
Crashton
Man I am glad you are here to be able to tell the tale. You did extremely well to catch your car when the rear started to steer for you. Just WOW!
Old Aug 19, 2007 | 11:28 AM
mataku's Avatar
mataku
Wow.. sounds scary. Glad you got out okay. I've never seen the front control arms before, anyone have pictures of what that looks like?
Old Aug 19, 2007 | 11:34 AM
Crashton's Avatar
Crashton
I believe it was a rear arm that broke causing Ashley to have unwanted rear steering at freeway speed.
Old Aug 19, 2007 | 11:47 AM
COR BLMY's Avatar
COR BLMY
I had the same issue ... long ago.
Didnt remember anything to harsh but I crossed a railroad and the upper just collapsed.
The flat tire monitor did come right on so I did stop.
A tow truck took my car to the dealer....But they wouldnot warrantee.
I used 4 hose clamps ad a piece of 1' angle iron to drive from the dealer to my house after they REFUSED to do anything due to the suspension mods that I had
I have replaced with aftermarket.
The OEM arms have a hole in the middle, and as best that i can tell it is a "manufactured weak spot"
The design must be that if you hit something then the arm will give and not the rear spindle or its housing
NOTE:
If you change controll arms and have self leveling headlights ... take a look at my gallery for a home made sensor bracket.
Old Aug 19, 2007 | 11:55 AM
COR BLMY's Avatar
COR BLMY
I found my photo.
It did take a bit if "hit and miss" positioning to get the lights right.
But this does work.
Hope it is of help to others
Old Aug 19, 2007 | 04:58 PM
Penelope_the_MINI
so, if this fix isn't covered under the warranty like COR BLMY said. I wonder if some aftermarket control arms are cheaper than getting OEM. I could just get my car back from the dealer and fix that on my own. Hell, I'm a welder by trade; I was just considering taking it back to my shop and welding it back together. But, if this all gets fixed under warranty, then obviously I'll just do that.
Old Aug 19, 2007 | 06:31 PM
ScottinBend's Avatar
ScottinBend
DO NOT repair. If not covered under warranty just replace both bottom arms with aftermarket. Many good quality arms are avaiable from MINI vendors. It is probably all of about an hour job to replace.
Old Aug 19, 2007 | 06:53 PM
Crashton's Avatar
Crashton
+1
Old Aug 19, 2007 | 06:59 PM
COR BLMY's Avatar
COR BLMY
dont fix them .... I have 3 in my garage (upper and lower can be interchanged )
Or buy aftermarket...
some in this forum NOW
https://www.northamericanmotoring.co...d.php?t=111249
Old Aug 19, 2007 | 09:02 PM
70spop's Avatar
70spop
Holy carp!!! Wow! Glad you were able to catch it and are OK. I'm glad I put some aftermarket control arms in my '03.
Old Aug 21, 2007 | 06:07 PM
Penelope_the_MINI
Perhaps a little more than expected...
Well, they called me back today (tuesday evening) and told me that after an initial look, it looks like the upper control arm may have been bent as well from the shock of the whole thing. She said, there gonna look at it again in the morning with a little more detail and determine if they're gonna cover it under the warranty. She (a service advisor @ Bob Smith MINI) prepared me for 'worst case' and told me that it could cost about $1000 or so to fix. God, I really REALLY hope they fix it under warranty. I was told that the foreman will look at it tomorrow and determine whether it happend as a result of a part malfunction/part stress, or if its a result of hitting large bumps and potholes. I asked her: "Aren't bumps and potholes what cause the part to malfunction in the first place? and every single car on the road hits hundreds of bumps and potholes a day? How could this NOT be covered under warranty? She kind of 'copped' out and told me the foreman will make the decision. If they tell me tomorrow that I'm gonna have to pay for it, I'm thinking about calling MINI USA to appeal.
Whadda you think?
Old Aug 21, 2007 | 06:22 PM
Donna/Mike's Avatar
Donna/Mike
Sand Dollar Collector
OMG!! That must have been SO scarey! I can't even imagine how you felt..
I cannot imagine that it won't be covered under warranty. Don't let the dealership bully you. If by chance, you don't get satisfaction from them, then yes, I'd be on the phone with MINIUSA in a flash...
Donna
Old Aug 21, 2007 | 06:36 PM
Penelope_the_MINI
Donna
Thanks for the support!
Old Aug 21, 2007 | 06:37 PM
89AKurt's Avatar
89AKurt
Wow, when that happens I hope I'm in a good position.... not the fast lane.
If they refuse to honor the warrantee, comment that you will post this story on the forum, might help you to threaten that.
Old Aug 21, 2007 | 06:45 PM
70spop's Avatar
70spop
Well, duh!! A) The part obviously malfunctioned. B) EVERY vehicle hits large bumps and potholes occasionally (except, maybe race cars that are 100% track). C) If they didn't take 'B' into account when designing the parts, they are idiots.
I realize the cars are not off-road machines, but any fool could tell them that the roads in the U.S. are crap, and getting worse by the day. It's impossible to dodge all of the potholes and bumps. This is not a part that should fail, ever, barring something like slamming the car sideways into a curb. Unless they can prove that that happened, they should cover the part without question.
Old Aug 22, 2007 | 08:32 AM
BMWNA's Avatar
BMWNA
I'm with MINI USA. I've passed this message on to a MINI National Customer Relations Representative who will be in touch with you soon.
Old Aug 22, 2007 | 09:38 AM
JIMINNI's Avatar
JIMINNI
Wow first time ive seen a MINI USA person in here, glad to see you are involved .
Old Aug 22, 2007 | 05:29 PM
Penelope_the_MINI
Wow! Thank you, My email is asotoole@yahoo.com.
Old Aug 30, 2007 | 09:06 AM
Bluegarvis's Avatar
Bluegarvis
Ashley- Any resolution to this?
Old Aug 30, 2007 | 10:06 AM
Sin MINI's Avatar
Sin MINI
Note that one of the White Roof Rdio dudes (forget which) had a similar issue and recommended that folks inspect their control arms.
I'm beginning to see a trend here...
If MINI won't work with you, there's always comprehensive insurance coverage. Of course that's always an ugly option with deductables, possib;le rate increases...
Old Aug 30, 2007 | 10:17 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
btw, I installed another set of non-OEM control arms and just left the heallight levelor off. Hasnt made any difference at all... although I thought it might. Simple fix it was.
