hubcentric-vs-wheelcentric
Old Aug 15, 2007 | 07:04 AM
edubledie's Avatar
edubledie
whats the differed between hubcentric and wheelcentric rings... i was advised once that hub* is better....
Old Aug 15, 2007 | 07:34 AM
ScottinBend's Avatar
ScottinBend
never heard of wheel-centric.........hub-centric is what you want. Make sure the wheel dealer includes the correct hub rings for your car.
Old Aug 15, 2007 | 07:36 AM
edubledie's Avatar
edubledie
do you know what the purpose of the ring is ?
Old Aug 15, 2007 | 07:38 AM
mozzarella's Avatar
mozzarella
I believe it is to fill the gap between the dia. of the hub and the wheel.
Old Aug 15, 2007 | 07:59 AM
ScottinBend
Most aftermarket wheels are NOT brand specific. The wheel hub is formed out larger than needed and then the dealer supplies make-specific rings that are installed between the wheel and the cars hub.
Old Aug 15, 2007 | 08:02 AM
PlayPlay's Avatar
PlayPlay
If anyone has a need for 65mm outer dia. and 56.1mm inner dia (mini size), I have two new sets (4 rings each) for sale. They are from Mackin Industries.
Old Aug 15, 2007 | 08:33 AM
kenchan's Avatar
kenchan
i think he meant lug-centric.
Old Aug 15, 2007 | 09:22 AM
Robin Casady's Avatar
Robin Casady
FWIW: CenterLine claimed that the RPM polished aluminum wheels I bought from them were "lug-centric", but I've had to get centering rings for them.
Old Aug 15, 2007 | 10:17 AM
PlayPlay's Avatar
PlayPlay
uh oh here we go on the whole lug-centric vs hub-centric debate again
Old Aug 15, 2007 | 02:27 PM
kenchan's Avatar
kenchan
not really a debate. do wat you need to do to make your wheels work
for you.
Old Aug 15, 2007 | 03:06 PM
Wake|MCS's Avatar
Wake|MCS
If their lugcentric that mean the hub-rings are necessary to CENTER the wheel on the hub. Yes, running hub-rings does make mounting the wheels easier/faster but after a couple times you learn to get pretty good at it. I'm not running hub-rings on my SSR's and I've gotten better at swapping wheels now.
Theres no better or worse really, as long as it works without vibrating...
