Interior/Exterior Removing door pulls?
Old Aug 15, 2007 | 06:01 AM
grassfolk420's Avatar
grassfolk420
Anyone here know how to remove the door pulls on a 2002 Cooper? I want to paint tham and my downtubes...
Thanks,
Justin
Old Aug 15, 2007 | 07:37 AM
ScottinBend's Avatar
ScottinBend
I believe you need to pull the door panel off. But you can check out this site for an exploded view of the MINI parts.
Old Aug 15, 2007 | 12:54 PM
grassfolk420
Thanks for the info...looks as if reside in the same area. I'm over by the Bagdad. Do you guys have a website for the PDX Mini club? Oops...I guess your in Bend...
Old Aug 15, 2007 | 05:46 PM
ScottinBend
LOL yep. Get to live in the hot spot.
The PDX club website is www.pdxmini.org.
Old Aug 15, 2007 | 07:57 PM
onasled's Avatar
onasled
As I remember it's not an easy job. In fact it might be a nightmare.
Old Aug 15, 2007 | 08:06 PM
EDM's Avatar
EDM
Ha! I finally have useful info!
1. Remove the small white reflector on the top corner of the door.
2, Unscrew the 4 torx head bolts on the door.
3. Start at the bottom of the door with something small and plasctic to begin prying the panel off. there will be plastic clips on the sides and bottom and metal hangers at the top. The panel simply pops off
4. The tweeter and door pull are in the same unit, retained by 3 phillips head screws. once they're off remove the wire going to the door pull and the wire to the tweeter.
After that your have the pull and tweeter together, you could further remove the pull itself or mask the rest of it and spray it right there.
wow, now thinking about it i hope you talking about the inner ones...
Old Aug 15, 2007 | 08:14 PM
onasled's Avatar
onasled
thought it was outer, but not sure....
Old Aug 15, 2007 | 08:15 PM
PGT's Avatar
PGT
it's not bad. I did my driver's door and am going back in tomorrow to swap it and the passenger's side for a spare set I painted off the car (when I wasn't in a hurry to get it all back together).
Taking the door panel off is the easy part. The challenging part is getting up inside the outer skin to loosen the two bolts. The window is in the way so you have to squeeze your hand in between it. It helps to drill a pair of holes in the inner skin and putting a light in the bottom of the door to help you see what you are doing.
Old Aug 15, 2007 | 08:19 PM
EDM's Avatar
EDM
is he talking about the inside or outside? this is confusing
Old Aug 15, 2007 | 08:20 PM
PGT's Avatar
PGT
maybe he's talking about the door panels themselves
Old Aug 15, 2007 | 08:28 PM
EDM's Avatar
EDM
since he's talking about spraying the downtubes, im thinking hes asking about the interior.
Motown
Apr 20, 2018 09:31 AM
joedotmac
Aug 28, 2015 01:04 PM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
