R56 Bluetooth in the R56
Old Aug 12, 2007 | 11:13 PM
MiniSD's Avatar
MiniSD
Does anyone have problems pairing your phone with this car? My new LG VX8700 does not work If anyone has a phone that is 100% compatible with your Mini, please share your phone brand and model. Thanks
Old Aug 12, 2007 | 11:22 PM
gregdconsulting's Avatar
gregdconsulting
My Motorola Pebl works just fine with my R56. The address book downloads as well.
I had trouble getting it to pair with the car using the all zeroes code. When I switched the code to all ones it paired up right away. When the MA paired the phone with all zeroes it worked, and then I deleted the pairing and tried to do it again, but the zeroes didn't work for me, then changing to ones did.
Old Aug 13, 2007 | 03:46 AM
emtrey's Avatar
emtrey
motorola razr works fine.
Old Aug 13, 2007 | 04:30 AM
Coffeeman's Avatar
Coffeeman
Be careful....any phone not on the "approved" list, has the potential to fry the MINI's Bluetooth module. More on this in the Bluetooth forum, and in the latest threads in "Things You Did Not Know about the R56"
Old Aug 13, 2007 | 07:27 AM
Phil K's Avatar
Phil K
Go to: http://wireless4mini.com
Old Aug 13, 2007 | 07:53 AM
andyde's Avatar
andyde
My Treo works great...
Old Aug 13, 2007 | 08:45 AM
Robin Casady's Avatar
Robin Casady
Are they covering this under warrantee for you, or are they claiming it is your fault for using an unapproved phone?
Old Aug 13, 2007 | 09:21 AM
ChrisSBU's Avatar
ChrisSBU
Hi guys...just picked up our new mini about an hour ago, and we were able to pair my wife's VZW Razr V3 to the car without issue, however, it does not appear that the address book wants to transfer over at all, and the voice dialing, even sitting in a quiet dealership, seemed totally useless not understanding a single digit spoken.
Anyone else's experiences or hints?
Old Aug 13, 2007 | 09:28 AM
Coffeeman's Avatar
Coffeeman
So did mine, until the Bluetooth module's memory became full of repeated phone book loads. Took about three months, then it fried the Bluetooth module.
Old Aug 13, 2007 | 09:59 AM
Loony2N's Avatar
Loony2N
My Blackberry 8703e works great. Voice recognition is very good, too. But I don't think that would be a function of the phone you are using.
Old Aug 13, 2007 | 02:01 PM
emtrey's Avatar
emtrey
1. Here is what I discovered about programming the phone to accept voice commands from the steering wheel buttons--
After a few very frustrating attempts to get the phone programmed to accept voice commands. I have figured it out ( THIS IS FOR PHONES THAT LOAD THE ADDRESS BOOK W/O THE VOICE COMMANDS--LIKE MY RAZR....here ya go------------
The first command after pressing the MSFW button is [SIZE=4]SAVE NAME[/SIZE] ( not store name)
[SIZE=4]Wait[/SIZE] thru the suggestion to continue till it says speak now--SAY NAME, repeat name
then it will say continue again--wait for speak now...say number, say the phone number connected to the name-- it will repeat number back--
then it will say continue---it will say speak now---say number (1-10) (I suggest making a list first numbering the names you want listed-the number you speak at this point will assign the position in your phone book of the name you are working with.
then the last command after waiting again thru continue and speak now is SAVE. Name and number are stored for use hands free. EG...dial name..... IT WILL ASK IF YOU WANT TO CALL AND SAY [SIZE=4]YES [/SIZE]AND IT CALLS the name you loaded....NOT PERFECT BUT IT WORKS....
That is all it takes....bottom line --wait till it tells you to speak and be patient..its slow. Hope this helps.
Old Aug 13, 2007 | 03:03 PM
thejonathanpaul's Avatar
thejonathanpaul
Hey I just orderd my 07 cooper with bluetooth how will my iphone work will I have full address book and the whole works?
Old Aug 13, 2007 | 03:42 PM
dmeadow's Avatar
dmeadow
I've got a Motorola Razr V3, as well. In a number of posts I've seen no one has a problem with Motorola phones. Bluetooth problems with other phones are many, including some problems noted on the BMW website. Mostly has to do with call drops.
Mine works fine. It downloaded the address book and the voice recognition function works very well. The people I've spoken with on the hands-free have said that my voice is clear, but there is some feedback such that they can hear their own voices.
My one complaint is the voice they chose for the voice recognition instructions-- a male with an American accent! I want Miss Moneypenny! (And it is OK if she calls me "James").
Old Aug 13, 2007 | 07:26 PM
Sowellman's Avatar
Sowellman
I also have a Razr. My address book downloaded automatically and I haven't had any problems with the bluetooth system.
As far as the voice recognition goes, the microphone is located on the right side of the overhead unit. There's another thread that talks about how to move it over to the left side. It works much better there.
I don't mind the man's voice. Provides a contrast to the woman on the navigation system. But I'd rather have a British accent rather than the generic American news anchor voice.
Old Aug 13, 2007 | 08:06 PM
SimpsonGI's Avatar
SimpsonGI
Coordinator :: Emerald MINI Car Club
Ah hah, Sowellman beat me to the punch. You may want to check the location of the microphone. See this thread here. It looks like there is a 50/50 chance it will be installed on the passengers side instead of the drivers side of the vehicle.
Old Aug 16, 2007 | 07:56 PM
roadguy54's Avatar
roadguy54
OK... probably one of those things everyone else knows about ... but... I DIDNT order the bluetooth option ... but DID order the MF steering wheel. Don't know what I was thinking... but now that I would like to have it ... my dealer says there's no way to retrofit the bluetooth so that I can use the steering wheel buttons.....is that really the case??......
Old Aug 16, 2007 | 08:49 PM
artsmini's Avatar
artsmini
Motorola RAZR, works fine. Had a Motorola SLVR, also worked fine.
Old Aug 16, 2007 | 09:00 PM
Tharkun's Avatar
Tharkun
We have three of the LG VX8300 everything works including the phone books, I seen a post that someone had the LG VX8600 that worked also.
Old Aug 16, 2007 | 09:21 PM
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
My Motorola L6 pairs up nicely, as I suspect the L7 would also.
Old Aug 16, 2007 | 11:22 PM
SimpsonGI's Avatar
SimpsonGI
Yes, the LG VX8600 works without any issues so far, including the phone book.
Old Aug 17, 2007 | 12:08 AM
Melor's Avatar
Melor
I was inspired by the bluetooth posts and moved my microphone to the left side and paired with my iPhone. The directory moved over and it works well. I recorded two names for voice recognition and that also seemed to work well.
Paul
Old Aug 17, 2007 | 12:11 AM
bart5467's Avatar
bart5467
it took a while 4 mine 2 work but my Samsung Sgh-620(or modle # like that) works just fine i love it
Old Aug 17, 2007 | 12:57 AM
MiniSD's Avatar
MiniSD
I just went out and bought the new LG VX8550 Chocolate, and it's working fine now The phone book works fine, but when I say "Dial Name" the car tells me that my phone book is empty Do we have to set this option up? If so, how?
Luan
Old Aug 17, 2007 | 04:44 AM
BludyL's Avatar
BludyL
Here's my experience. I have a Motorola Q. See my thread post
https://www.northamericanmotoring.co...43#post1545343
I had all sorts of problems after I had set up the intial pairing. Then subsequent times, the phone just wouldn't re-pair. Sometimes it worked, sometimes it didn't. Sometimes, I would be talking on the phone for an hour while driving, and suddenly it pairs up to the car. One time, I drove an two hour commute and the phone paired up just as I turned into my parking spot. I could have it paired, stop the car to say get gas, start the car and no pairing. I would try Deleting the phone and restart pairing, didn't make a difference. It was zany.
Another thing that didn't work in my car is my voice recognition. I would hit the little button on the steering wheel, and nothing.
So two weeks ago, I started a week long vacation. I dropped the mini off at the dealer and told them they had all week to get the voice recognition working. They got it fixed but updating the firmware.
https://www.northamericanmotoring.co...56#post1688756
All this week, my phone has paired perfectly every time. 100%. Turn the car on, phone pairs. Finally all is right in MINI Land.
But I'm thinking of getting the new Motorola Q9M from Verizon when it comes out later this month or early next month.
Old Aug 18, 2007 | 12:14 AM
maxshrike0's Avatar
maxshrike0
Old Motorola E815...works great!
My ol' Moto E815 pairs up nicely... I was pleasantly surprised that I can access the full phone book on the phone from voice commands... I did move the microphone to the driver's side. In general, I find the voice recognition... odd. It sure does butcher common words, names when it repeats them back. Ah, that mini personality!
I'm surprised at how quickly the mini pairs up with the phone, as soon as I start Max, the phone is hooked up and ready to go.
Since my clunky ol' e815 works great, I'm a little reluctant to change it for a new model!
Hey, anyone try buying an armrest insert for their phone? I presume only approved phones have inserts? Does this work well? I'm wondering if the call quality goes up with the insert, since it hooks the phone to the mini external antenna!?!
