R56 Swapping Pedals
Old Aug 9, 2007 | 01:15 PM
mufflethis's Avatar
mufflethis
Swapping Pedals
I'm planning to get different pedals for my MCS to make heel-toeing a little easier, basically I can't get secure footing on the brake while blipping the throttle since the pedals are a little too far apart. My question is, has anyone take the pedals off? How is the rubber on the pedals attached is it just adhesive? I also assume that the screws are below the rubber, right? Is there anything else I should know when taking the pedals apart?
Old Aug 10, 2007 | 01:23 PM
mufflethis's Avatar
mufflethis
Anyone? :impatient
Old Aug 10, 2007 | 01:30 PM
Bhatch's Avatar
Bhatch
you need to learn to heal and toe better cause it is very easy on the mini.
Old Aug 10, 2007 | 01:49 PM
lhoboy's Avatar
lhoboy
My engine can't be blipped. Needs some aftermarket software.
Old Aug 10, 2007 | 01:53 PM
lhoboy's Avatar
lhoboy
Bhatch,
You must have some real fat feet or maybe it's that heal you're using. I don't have that particular body part.
I've been heel/toeing for decades and find the MINI to be the most difficult of any of my cars. Much more difficult than even my full size pick-up.
mufflethis,
The Ultimate Pedals come highly recommended by a bunch of MINI drivers: http://www.outmotoring.com/mini-coop..._manual.h tml. You can find a discussion on another recent thread.
I'll give them a try after I get the engine to "blip" with an LDG tune.
Old Aug 10, 2007 | 01:56 PM
gte123v's Avatar
gte123v
Originally Posted by lhoboy
You must have some real fat feet.
mufflethis,
Check these out: http://www.outmotoring.com/mini-coop..._manual.h tml
I think he's saying his feet are too small since he think the pedals are too far apart.
Old Aug 10, 2007 | 01:58 PM
gte123v's Avatar
gte123v
what do u mean by secure footing? only your toes should be on the brakes, unless you have like size 6 feet heel and toe should be no problem. Maybe you should get some driving shoes as they give you a better feel of everything.
Old Aug 10, 2007 | 02:11 PM
lhoboy's Avatar
lhoboy
Classic racing technique is with the shoe flat covering both pedals and the foot is rolled side to side. On big sedans, where the pedals are further apart, the arch or heel is on the brake and the toe on the throttle. If you do it the other way around your heel is on the throttle pivot and not doing anything.
Old Aug 10, 2007 | 02:12 PM
lhoboy's Avatar
lhoboy
I was responding to Bhatch.
Old Aug 10, 2007 | 02:53 PM
djam43's Avatar
djam43
Jeepers ,,, any smaller pedals on the Mini would be dangerous.
Old Aug 10, 2007 | 03:06 PM
unixgal's Avatar
unixgal
Twisty Road Lover
Those pedals are listed only for the MC/MCS up to '06 and not the R56. Have you heard somewhere that they fit the '07 as well?
Old Aug 10, 2007 | 05:46 PM
lhoboy's Avatar
lhoboy
Ideally, the pedals should be right next to each other with the brake pedal about an inch closer to the driver than the throttle. Doesn't matter how big they are as long as there is plenty of grip and they're close together. When I've fabricated pedals for my race cars, I used metal pads and bonded grip strip material (coarse grit) to the surfaces.
Old Aug 10, 2007 | 05:47 PM
lhoboy's Avatar
lhoboy
Give them a call. If they don't fit, I'm certain they'll be making some soon that do fit.
drrigg
May 27, 2022 03:31 AM
Doc Pain
Mar 10, 2021 04:50 AM
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
scfiveo
Sep 27, 2019 02:27 PM
eliseo1981
Nov 2, 2015 11:24 AM
