R50/53 Dead clutch on my 2006 MCS
Old Aug 8, 2007 | 07:01 PM
cbayles's Avatar
cbayles
I pushed my clutch to the floor this evening and decided to stay there. I have a 2006 MCS with 24,315 miles on it. I haven't been hard on the clutch by any means and I haven't noticed any warning signs that it was about to go. Luckily I was still in a restaurant parking lot instead of the middle of nowhere since it took nearly three hours for the tow truck to arrive after I called MINI roadside assistance.
Any ideas on what might have caused this?
Old Aug 8, 2007 | 07:15 PM
MI MINI S's Avatar
MI MINI S
It my not be the clutch ...maybe a broken clutch return spring?
Old Aug 8, 2007 | 07:23 PM
FLMINI1048's Avatar
FLMINI1048
I had that exact same problem in my 99 Miata and it was a bad seal on the clutch slave cylinder. The part was only $40 at Napa and it was an easy fix.
Old Aug 8, 2007 | 07:26 PM
wtadye's Avatar
wtadye
Coordinator :: PDX MINI Club
It's been a common problem for the clutch slave cylinder to fail and the pedal to stay on the floor.
Old Aug 9, 2007 | 04:19 AM
k_h_d's Avatar
k_h_d
Is there a DIY Write up on it?
Old Aug 9, 2007 | 05:05 AM
nixjosh2's Avatar
nixjosh2
^+1 Slave Cylinder, easily replaced under warranty, happened to me at 25k
Old Aug 9, 2007 | 06:30 AM
thulchatt's Avatar
thulchatt
Chris,
No help on the problem, but where did MINI Roadside take your car, Global or Nashville? Also let me know if there is anything I can do to help.
Jeff
Old Aug 9, 2007 | 06:33 AM
Tomcatta's Avatar
Tomcatta
I agree clutch slave cylinder internal leak (no fluid on ground).
Old Aug 9, 2007 | 08:07 AM
DixonL2's Avatar
DixonL2
Let us know what the resolution was... and good luck
Old Aug 9, 2007 | 10:54 AM
cbayles's Avatar
cbayles
Originally Posted by thulchatt
Chris,
Jeff
MINI Roadside towed it to Global in ATL since it was the closest dealer. I received a call from a service advisor @ Global this morning. He asked me what was wrong with the car. I guess MINI roadside doesn't pass the info on to the dealer. You'd think a clutch pedal on the floor and the shifter stuck in neutral would be a dead giveaway.
The service advisor also asked if there's anything else that's wrong with the car. I told him that it runs like total crap the first 10 minutes after I start it (same with the wife's car). He asked me what kind of gas I use and I told him Exxon or BP/Amoco 93 octane. Apparently those fuels aren't on MINI's recommended fuel list. WTH? It's not like I'm filling up with Walmart or Raceway 87 octane.
I let you all know the outcome once I hear back from the dealer.
Old Aug 10, 2007 | 04:15 PM
cbayles's Avatar
cbayles
It was a faulty slave cylinder. Thanks for all the input!
Old Aug 10, 2007 | 05:09 PM
eager2own's Avatar
eager2own
NAM is a crazy site - anytime I have an issue and come on here to ask about it -- it turns out someone else has just asked the same question.
Just tonight, my wife called me from the mall: car is stuck in neutral (she blamed the short shift kit 'cause she hates it). I went out there and found that the clutch pedal was "stuck to the floor". I pulled it up, and the car ran normal, so I was able to get it home -- but I guess I'll have the cylinder looked at. I'm still under warranty -- I just hope they don't give me a hard time about the short shift kit (though I realize they're unrelated).
Old Aug 10, 2007 | 05:31 PM
cbayles's Avatar
cbayles
Yeah, I got the lecture about my "after-market" parts, but I told the service advisor they had nothing to do with the slave cylinder crapping out after 24K miles. I just hope my wife's automatic doesn't decide to implode because it's been shifting pretty rough lately.
Old Aug 10, 2007 | 06:09 PM
thulchatt's Avatar
thulchatt
Chris,
Next time you might want to take Zipper to MINI of Nashville. They are more mod friendly. The most I have gotten from the is "oh, you have a couple of non-OEM parts on there".
Not sure what they would do if push came to shove, but I run out of warranty in December anyway.
jst_bc
Sep 11, 2015 07:45 AM
Drumsound
Aug 25, 2015 05:22 AM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
keck.j
Aug 18, 2015 08:18 PM
minipopkart
Aug 13, 2015 05:22 AM
