Suspension question on m7 srp
question on m7 srp
this may sound silly but if i take the nut off the struts bolt to place the SRP's on ....will the bolt fall through ? is the bolt welded to the strut ? im trying to determin if i will need to take my wheels and wheel wells off to do this install....help is appreciated.
hey thanks for the response....i dont quite understand though i have everything stock so the bolt doesnt needs to be held underneath with a wrench while i tighten the nut on top does it ? does this stock strut plate hold those bolts through the holes as i take the nuts off ...im worried that the botl will fall to the ground or in my car somewhere if i take the nut off
Grizld700
Dec 30, 2015 10:47 AM
Navigation & Audio How much power do you get through the Y-cable--and can it be increased?
twriter
Oct 2, 2015 03:14 PM
