Suspension Click clank clunk!
Old Aug 6, 2007 | 09:23 AM
MiniStupidfun's Avatar
MiniStupidfun
Click clank clunk!
I have been noticing a slight Clank sound comeing from the front of my car . Im guessing it is something related to the suspension because i only hear it when im taking off from a stop or when im stoping and going in traffic. If anyone has had this problem and knows the solution please help me.
Dan
Old Aug 6, 2007 | 09:54 AM
vader's Avatar
vader
Front wheels been removed lately? If so, check the torque. Loose wheels can cause the mentioned sounds at stop an start only.
Old Aug 6, 2007 | 10:03 AM
MiniStupidfun
Yeah, ill double check that
Old Aug 6, 2007 | 10:13 AM
UKSUV's Avatar
UKSUV
Sounds like a broken motor mount....
Old Aug 6, 2007 | 10:38 AM
MiniStupidfun
the top (two) visable motor mounts look fine
Old Aug 6, 2007 | 10:50 AM
Tüls's Avatar
Tüls
Turbius Maximus
Check the lower one motor mount... also check the strut towers... something may have let go there...
maybe have someone work with you in a large lot with nothing around and open the hood and start and stop with them listening to see where it's coming from ... LOL crazy I know... but if it is that easy... LOL...
Old Aug 6, 2007 | 12:31 PM
MiniStupidfun
ill take a look and let you guys know what i come up with.
Old Aug 6, 2007 | 04:18 PM
MiniStupidfun
Well i went out for a drive to get a better listen to what is going on. The noise that im hearing is not at all loud. The only thing that i can compair it to is if you have ever had a bicycle and the headset was loose, it kind out sounds like that. I have no vibrations and the car isnt pulling. i guess im gonna have to jack it up and crawl under it. no fun
Old Aug 6, 2007 | 04:23 PM
Tüls's Avatar
Tüls
Turbius Maximus
that's where the fun begins! LOL... ok ok it can be a pain... but just pretend its fun! LOL....
Old Aug 6, 2007 | 05:55 PM
SRTech's Avatar
SRTech
Dan
Check the belt tensioner. The little shock damper rubber bushings disintegrate in time.
Steve
Old Aug 7, 2007 | 05:14 AM
mini_macky's Avatar
mini_macky
i had a similar sound that was in my old MC, turned out to be worn tie-rods. i now have the same thing in my MCS, having the motor mounts checked & tie-rods as well
does it happen when you abruptly slow down? or when you're shifting and you suddenly let go of the clutch when in gear?
Old Aug 7, 2007 | 05:41 AM
MiniStupidfun
I can only notice it when in first gear but yes that is the case
Old Aug 13, 2007 | 04:29 AM
mini_macky's Avatar
mini_macky
any updates? problem solved?
Old Aug 13, 2007 | 09:32 AM
MiniStupidfun
I have been driving it Alot and the noise has yet to worsen. im gonna take a look at the lower motor mounts when i change the oil tuesday. ill let you guys know, and post pictures if need be.
Dan
Old Aug 21, 2007 | 04:58 AM
MiniStupidfun
Well just to update. Last night i installed the Helix Engine Dampener And no more noise.
Old Aug 21, 2007 | 06:28 AM
Tüls's Avatar
Tüls
Turbius Maximus
well that's good that the noise is gone... personally I am concerned as to why it was making it.... like if something is loose... and now the damper is keeping it from moving... if you know what I mean
Old Aug 21, 2007 | 09:09 AM
MiniStupidfun
oh yeah! that crossed my mind but what i didnt mention is that i also changed the oil and while i was under the car i checked everything that i could reach. Do you have any other suggestions Tuls
Old Aug 21, 2007 | 10:43 AM
Tüls's Avatar
Tüls
Turbius Maximus
ha ha no.... if it's gone good... maybe your motor was just hitting something... they tend to rock quite abit from the factory... when under load... maybe yours was just a little more than normal... LOL
Old Apr 23, 2008 | 06:09 AM
MiniStupidfun
lmao, it's been a while but i found the culprit. A bad tie rod
Old May 8, 2008 | 11:45 PM
Benibiker's Avatar
Benibiker
I have the same problem, do you think you really found the problem? How did you track it down to the tie rod? Help!
Sep 4, 2015 02:12 PM
Sep 2, 2015 12:57 PM
Sep 2, 2015 12:55 PM
Sep 2, 2015 11:15 AM
Suspension Products
Sep 2, 2015 10:32 AM
