R56 programming inside door handle behav.?
Old Aug 4, 2007 | 10:08 AM
leek's Avatar
leek
HI
Can you program how unlocking works when you pull the door handle? I don't like the double-pull to unlock, then open, I'd rather have one pull to unlock and open. I can't seem to figure this out from reading the manual, and I also clearly do not have strong enough google-foo to search for a previous thread on this (did find a few on failing door lock parts, though
Thanks for any advice,
Old Aug 4, 2007 | 10:20 AM
driverphil's Avatar
driverphil
No, Its a BMW trait
for good or bad, that's how they do it
Old Aug 4, 2007 | 10:28 AM
Scoopmama's Avatar
Scoopmama
I THINK I read in the owner's manual PDF that your dealership can reprogram the handle function if you don't like it. Give them a call! Good luck!
Old Aug 4, 2007 | 01:14 PM
elmalloc's Avatar
elmalloc
Incorrect, dealer could have programmed how you wanted it at delivery time..probably still could. But this is a BMW default. :impatient
Old Aug 4, 2007 | 02:55 PM
leek's Avatar
leek
OK, next time it goes into the dealer for something I'll see if they can change it. Thanks!
Old Aug 4, 2007 | 04:00 PM
Nui's Avatar
Nui
Please let us know. Our dealer couldn't figure out how to do it.
Old Aug 4, 2007 | 04:35 PM
emtrey's Avatar
emtrey
my MA did it..Did not get set thru service dept. Sorry--can't remember how he did it. Did you try the owner's manual for the programmable turn signal stalk settings?
Old Aug 4, 2007 | 04:57 PM
kimmc's Avatar
kimmc
My understanding is that the only way to do it is to program the doors NOT to lock when you start the car or drive away. This means that you doors do not automatically locked, and remain unlocked, so you only have to pull the handle once.
You can program it yourself via the signal stalk set up.
If you find anything else from your dealer, please let us know..
Old Aug 4, 2007 | 05:17 PM
Nui's Avatar
Nui
What Kimmc said
Old Aug 4, 2007 | 05:22 PM
emtrey's Avatar
emtrey
My understanding is that the only way to do it is to program the doors NOT to lock when you drive away. You can program it yourself via the signal stalk set up.
CORRECT...you can not have lock on drive away and not be stuck with the dbl pull to open. That is how mine is programmed. I don't like the lock on drive away and find the BMW dbl pull to open very annoying.
I asked the MA and he said there is no way to program it any other way.
Old Aug 5, 2007 | 11:35 AM
leek's Avatar
leek
So you either drive with doors unlocked all the time or you do the double pull? I guess I'm stuck, then, since I do want the doors locked - last night some drunk chick wandering around after a street fest thought we were a taxi.
Old Aug 5, 2007 | 12:40 PM
emtrey's Avatar
emtrey
hahaha---I live in Chgo suburbs and completely understand.
Funny--mine is red/white and that is another Chgo Cab combo but it has never happened to me. I guess I don't spend enough time downtown.
Old Aug 5, 2007 | 01:22 PM
djam43's Avatar
djam43
I have the NAVI, so it is easy to see what you program or unprogram, believe me, your problem can be corrrected by understanding the function of the steering stalk button. do a little homework, you will figure it out.
Old Aug 5, 2007 | 01:48 PM
emtrey's Avatar
emtrey
you can do the unlock on drive away setup and just lock them manually using the toggle switch on the console. However, it does not change the dbl. pull. Once they are locked you need to pull twice to unlock unless you toggle them open first.
I would say I hope it was not one of my children BUT I have 2 sons. WHEW...
Old Aug 15, 2007 | 04:06 PM
leek's Avatar
leek
It was at the dealer for a software update and I asked if they could reprogram this. They said that some of the manuals are wrong, that the dealer CAN reprogram it, but only on the S model - and then, not on all S models. We don't have an S.
Old Aug 15, 2007 | 04:13 PM
rattmobbins's Avatar
rattmobbins
Say whaaa???? So they can reprogram to unlock and open with one pull???
Old Aug 15, 2007 | 05:12 PM
valthun's Avatar
valthun
All I know is that mine are set to not lock, so I haven't experienced this yet. But I am one of those that isn't in to locking the door when I drive away. It's a weird program setup though. I thought the idea was that you couldn't open the door while in motion, but when stopped and in Park, or nuetral you can then open with a single pull.
Old Aug 15, 2007 | 05:14 PM
andyde's Avatar
andyde
What !!?? Seriously, that would be awesome
there have been numerous posts here stating that it cannot be done, the Mini could not be programmed to automatically unlock its doors.
there is a thread floating arround here, I think it is "things you did not know about your R56 "...
please keep us posted, I'll be scheduling a premature visit to the dealer soon; if this in fact is now correct....
Old Aug 15, 2007 | 05:37 PM
leek's Avatar
leek
What I wanted was that they can be programmed to unlock and open on one pull instead of pull to unlock, pull to open. You know, like normal cars The service guy said it CAN be done, but only on the S, and then, only on SOME of the S. (Ses? S's? Ss?)
Old Aug 15, 2007 | 05:53 PM
ScottinBend's Avatar
ScottinBend
The service guy is wrong. The double pull is a mechanical mechanism, not electronic. You can have the car set-up to auto unlock when you turn off the car though.
Old Aug 15, 2007 | 06:06 PM
Sowellman's Avatar
Sowellman
Scott,
I haven't seen any reports that says the auto unlock is possible in an R56. And yet a lot of people have been screaming for it. Please share your source.
Old Aug 15, 2007 | 06:32 PM
andyde's Avatar
andyde
Scott, yes please share your source. This is what i was talking about..
Old Aug 15, 2007 | 06:56 PM
ScottinBend
Oops !! Sorry
My fault.....I assumed that it was still available on the 07's. I can't imagine why BMW stopped making it an option.
Guess the best bet is to turn off auto-locking. Bummer.
Old Aug 15, 2007 | 07:04 PM
Sowellman's Avatar
Sowellman
They swapped it for the secret compartment we received.
Old Aug 15, 2007 | 07:09 PM
ScottinBend
Doggone ! ! I want a secret compartment.........LOL
