help? Brake pad light just turn on
Old Jul 31, 2007 | 09:02 AM
musumekiller's Avatar
musumekiller
Hi everyone, I need some help. My brade pad light is on. I am in GTA. Anyone know if there is another place I can replace the pad other then mini dealership who can also reset the brake pad light on the dash? I do want to save some money!
Mini charge 186 for the front brake pad. Is this a reasonable charge?
thx so much
Old Aug 3, 2007 | 08:26 AM
///ACS330Ci's Avatar
///ACS330Ci
How mechanical are you?
https://www.northamericanmotoring.co...ad.php?t=43438
This is for the rears, but I'm sure if you do a search there's a front DIY too.
Old Aug 3, 2007 | 09:27 AM
cube17576's Avatar
cube17576
Coordinator :: STLMini
Anyone should be able to change the brake pads, but the sensor is a wear item as well and needs to be replaced to turn off the light.
Old Aug 6, 2007 | 10:50 AM
plantain's Avatar
plantain
Check your pad thickness visually.
With most wheels, you can look through the wheels and see the brake pad directly. The brake light will go off if EITHER the front or back pads are too thin, so you should examine them both to see which one is wearing faster.
OctaneGuy's how-to guide (referenced in message 2 above) has some great pictures that you can look at to compare.
Old Aug 8, 2007 | 10:35 AM
musumekiller
thx guys
I think I decided to bring it back to dealership. I am not a tech person and have minimum knowledge when it comes to fixing my mini. thx a lot.
W0TM8
Dec 19, 2019 07:50 AM
bjcarter2
Aug 31, 2015 04:03 PM
fjork_duf
Tires, Wheels, & Brakes
Aug 16, 2015 04:38 PM
