Stoptech 02 kit install on 06 mcs
Old Jul 30, 2007 | 08:06 AM
minimusprime's Avatar
minimusprime
so I've got a stoptech bbk en route that was originally installed on an 02 kit. The kit is shipping with front and rear stainless lines. From what I gather the rear lines will not work with my existing early 06 build mcs. However does any one know if the fronts will work?
Next question is what rear pads would you suggest and should I scoop up some powerslot rear rotors as well? I want to keep an even brake bias throughout the swap.
Old Jul 30, 2007 | 02:45 PM
UKSUV's Avatar
UKSUV
As far as I know the fronts will work....I don't remember them changing the part #.
Old Jul 30, 2007 | 03:20 PM
toddtce's Avatar
toddtce
Many of the 02 cars had rear hoses with banjo bolts to the caliper. You will probably need to get new rear hoses now with "direct thread" on them which screw right into the caliper body.
Old Jul 30, 2007 | 08:55 PM
minimusprime
I almost forgot... I'm away on business and can't check for myself.
does any one know if et 37 17x7 oz ultraleggeras will clear these w/out spacers. if I need em I want to have them waiting for me when I get back.
tia
Old Jul 30, 2007 | 09:10 PM
VoiD's Avatar
VoiD
tia
they won't clear without spacers...
Old Jul 30, 2007 | 09:44 PM
minimusprime
thamks for the answer void. ok I guess the next question is. can I run a 15mm spacer with a et37 wheel? if not what size should I be looking for?
Old Jul 30, 2007 | 10:00 PM
sprp85's Avatar
sprp85
et37 with 15mm spacer? eeekkkk it will poke.. a bit.. don't know what to suggest with the spacer.. i mean how much do you need ot clear the brakes?
Old Jul 30, 2007 | 10:10 PM
minimusprime
being away from my car right now I can't be sure. tbhi wouldn't mind a little poke... it's bump steer and my wheel bearings I'm concerned about.
Old Jul 31, 2007 | 01:17 PM
UKSUV's Avatar
UKSUV
I think with the 5mm spacers you would be okay....those "should" clear.
squawSkiBum
Oct 2, 2015 09:21 AM
Mini'mon
Aug 26, 2015 01:02 PM
