Double Head gasket ?
Old Jul 26, 2007 | 10:38 PM
kamikazy's Avatar
kamikazy
Yesterday I took my mini to garage to change the head gasket
I found double head gasket in my mini any one knows why there are double head gaskets?
Now it replaced by one head gasket is there any problem butting 1 instead of 2 head gasket?
Old Jul 27, 2007 | 04:35 AM
Minimad's Avatar
Minimad
Should only be one.....
2 = twice the chance to leak....
Old Jul 27, 2007 | 06:35 AM
ImagoX's Avatar
ImagoX
Sounds like the head might be slightly warped or something and they used the double-thickness of gasket to plug it perhaps... I'd have the garage check the egde for flatness since they have it apart...
Old Jul 27, 2007 | 08:03 AM
Crashton's Avatar
Crashton
That's a strange one???. I've never heard of double gasketing a head. I'm wondering if the head was shaved too much & that was a nincompoops way of lowering the compression. Before you reassemble that engine you need to determine why it was done. Don't just put it together without first having a competent machinist inspect the head & the top deck of the block.
I'm real curious to hear what you find.
Old Jul 27, 2007 | 08:23 AM
Ashley3D's Avatar
Ashley3D
Two head gaskets will do nothing but allow twice chance of leaking.
To check for warpping turn a steal-edge ruler or piece of glass on the edge and place them on the head. Make sure to check diagnally across the head as well as straight across. Use a torch on the otherside and see If there is light bleeding under the straight edge. If it is, then the head is warpped.
Lets hope is was a bloke with no mechanical skills.
Ash
Old Jul 27, 2007 | 01:02 PM
kamikazy's Avatar
kamikazy
thank you for your help
i will go & check the head.
Old Jul 30, 2007 | 11:28 PM
Latka's Avatar
Latka
I've heard of people using multiple gaskets to lower the compression ratio slightly, but it's a pretty backwards approach to the problem.
Old Jul 30, 2007 | 11:42 PM
user 7082082's Avatar
user 7082082
R u sure there was two gaskets ? Cus i just replaced mine and the factory one has two gaskets stock together. Its two thin gaskets connected together at 6 points i think. I think thats what you saw and calling it two gaskets. The new one came the same was my old one was , two thin gaskets.
Old Aug 4, 2007 | 01:20 AM
kamikazy's Avatar
kamikazy
Two separate gasket
not two thin gaskets
I don’t know why the previous owner put two head gasket.
Currently my mini is working fine after changing the head gasket set.
Old Aug 4, 2007 | 09:17 AM
Ashley3D's Avatar
Ashley3D
Is your engine a 1275 Metro lump or Mini? I found out the Metro engines head gasket in thicker than a mini one. This could be the reasoning behind it.
Old Aug 4, 2007 | 09:37 AM
kamikazy's Avatar
kamikazy
my engine is 998 (mini)
potterstein
Dec 30, 2024 05:18 PM
iclancy82
Jan 2, 2021 08:59 PM
Filmy
Sep 6, 2015 10:06 PM
Sep 2, 2015 09:05 AM
