Interior/Exterior Air Horn Install Question
Old Jul 25, 2007 | 02:20 PM
EDM's Avatar
EDM
I picked up a set of Hella air horns to install in addition to my stock set.
My stock horns have a brown wire and a red wire going to them, which is (-) which is positive (+)?
Can i just tap them each a run them to the compressor?
Old Jul 25, 2007 | 02:39 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The brown wire is (-), as is any solid brown wire in the car. Red of course is the (+) wire. If you plan on disconnecting the original horns to operate the air horns instead, you should be fine. However, if you want the original horns to blast along with the air horns, you will probably overload the horn circuit unless you use a relay and create a separate branch circuit for the compressor.
Old Jul 25, 2007 | 02:44 PM
EDM's Avatar
EDM
do i just manually disconnect the horns by removing the plug on the back of each
Old Jul 25, 2007 | 04:36 PM
meh's Avatar
meh
A relay is definitely the way to go and will never overload your system. I just installed a set of air-horns in my Cooper and used the red wire from the original horns to feed the relay (the ground can just go to the mounting bracket; for the heavy load side of the relay I used the terminal at the back of the fuse block (next to the air box). I just unplugged my original horns but have the option to plug them in at any time (not that I will need them)
Old Jul 25, 2007 | 04:42 PM
EDM's Avatar
EDM
Thanks so much for all your feedback, i ended up just tapping the two original wires from the horn i unplugged, led them to the compressor, lines from the compressor to horns!
Sounds SWEEEET!
Old Jul 25, 2007 | 05:01 PM
NMgokart's Avatar
NMgokart
Where did you mount the trumpets? Pics?
Old Jul 25, 2007 | 07:18 PM
EDM's Avatar
EDM
i mounted the trumpets using zip ties under the passenger side hood grill where the A/C lines are.
doesnt look too bad, and sounds awesome!!!
Has anyone tried running both horns without an additional relay?
Old Jul 26, 2007 | 08:50 AM
phydeaux's Avatar
phydeaux
I've got my dual Hella's mounted on the passenger side, up by the firewall. Sounds like much the same place you did it. I've not wired them up yet, but should be able to do that this weekend.
Old Jul 26, 2007 | 11:56 AM
EDM's Avatar
EDM
Old Jul 26, 2007 | 06:16 PM
EDM's Avatar
EDM
i just said F-it and plugged in my stock horns in addition to the Air Horns
works great! no relay overload, no blown fuse.
EVEN LOUDER!
Old Jul 30, 2007 | 03:52 PM
DeniseK's Avatar
DeniseK
Well, where are the photos?
Old Jul 31, 2007 | 09:44 AM
phydeaux's Avatar
phydeaux
Gonn ahave to take them with my cell phone. Left the camera at home. D'oh!
W0TM8
Dec 19, 2019 07:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
