R50/53 So I raced an F550 Maranello today...
Old Jul 16, 2007 | 03:30 PM
hegira's Avatar
hegira
and blew him into the weeds.
Seriously now, Folks.
I've been reading about peoples' mileage claims, and have read many for either exceptional or terrible mileage, with the disclaimer of other than stock wheel/tire combinations. It was my understanding that our ECUs would throw a CEL if we varied the tire circumference by more than a few percent.
Am I corect, or out in left field (familiar territory) again?
And for what it's worth, Emily ('02 MCS, 6-speed, Chili Red with a black hat, just turned 26,000 moles) gets around 23-26 MPG.
Thanks,
Hegira
Old Jul 16, 2007 | 03:33 PM
ChrisW's Avatar
ChrisW
and this has what to do with you racing a Ferrari? I'm sure he/she wasn't trying.
Old Jul 16, 2007 | 04:00 PM
hegira's Avatar
hegira
Oh nooooooo...
He was running WFO, and after I hit third gear, he was just a spot in my rear-view mirror.
Old Jul 16, 2007 | 06:14 PM
ScottinBend's Avatar
ScottinBend
Tire diameter has nothing to do with fault code......it would only trigger the flat tire light.
Old Jul 16, 2007 | 06:19 PM
Crashton's Avatar
Crashton
Hello out there in left field. As long as the tires are all the same size you won't have any problems.
Old Jul 16, 2007 | 07:40 PM
MUShadd's Avatar
MUShadd
im confused.
Old Jul 16, 2007 | 07:47 PM
Ryephile's Avatar
Ryephile
I've run tire sets with diameters ranging from 22.7" to 25.1", and didn't even get a flat-tire light, let along a CEL. I don't see a reason for a CEL anyway, as the ABS sensors aren't tied to the ECU.
Old Jul 16, 2007 | 08:39 PM
JustJAY's Avatar
JustJAY
Originally Posted by mushadd
im confused.
+1
Old Jul 16, 2007 | 09:00 PM
chrisneal's Avatar
chrisneal
Old Jul 16, 2007 | 09:04 PM
minjae's Avatar
minjae
im confused.
+2
Old Jul 17, 2007 | 02:43 AM
hegira's Avatar
hegira
Sorry if I've caused any confusion with the F550 claim. It was said in jest, tongue-in-cheek, as a sort of ice breaker....
As far as our cars throwing a CEL due to deviating from the original tire circumference, I must be mistaken. My thinking was that the speedometer, and associated peripherals (cruise-control, trip-computer, etc.), would be thrown off.
Sheesh....
Old Jul 17, 2007 | 06:20 AM
CooperSKart
Maybe it would have been more clearly in jest if you said you blew the pants off a top fuel dragster at the dragstrip? (I knew it was in jest right away fwiw). I do agree that the wheel diameter is only likely to cause issues if they are different from each other.
It does also seem that mileage #s are all over the board (pun not intended). I typically get around 23 - 24 mpg just around town (lots o stoplights) & about 31 - 32 on the highway cruising ~65-70 mph. Those #s are just calculated based on miles per individual tank full (when pump clicks off).
Old Jul 17, 2007 | 06:38 AM
Mini S Pilot's Avatar
Mini S Pilot
Originally Posted by hegira
Oh nooooooo...
Have I heard that somewhere before?
No, not recently anyway. I have a feeling that once I change up from my ride below to my Mini when it arrives I'll be in for a different type drive for sure. I'll be using so much less gas though.
Chibi2
May 19, 2016 03:46 PM
gnhovis
Dec 14, 2015 05:31 PM
pahg
Oct 5, 2015 11:50 AM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
potterstein
Oct 1, 2015 07:10 AM
