Navigation & Audio got my amp for the MINI
Old Jul 15, 2007 | 01:27 PM
pimpedout97x's Avatar
pimpedout97x
last time i posted videos of my 12" RE XXX on 1800w, all the vibrations from the bass, alot of you flamed me, but ill still post pics, and when the box gets built ill post the worklog, for those of you into car audio. id still like all your opinions though.
anyways, the new sub will be a 12" resonant engineering MT, the box is going to be i believe 2-2.5 cubic feet, tuned most likely at 35hz.
i may be trading this amp for a memphis mcd2500 (2500w rms) as its alot skinnier, and may be easier to fit in my car. i dont know if this amp will fit when the box is done, but ill have to wait and see.
anyways, its a Powerbass XA-3000D, and a Kinetik HC2400 battery.
im going to replace the stock battery with this one as its alot bigger (67 lbs) and should help with the voltage drop. i really dont want all this weight, but i couldnt pass up the deal, so i bought it. when i get more money in the future and add more power to my MINI, it wont matter though
amp is 3000w rms @ 1 ohm
Old Jul 15, 2007 | 01:35 PM
btallack's Avatar
btallack
That is a beautiful amp, but I just have to ask, why do you need so much bass in such a small car?
Old Jul 15, 2007 | 01:41 PM
pimpedout97x
its not that i "need" so much, i just like alot of bass.
im just real in to car audio, its pretty much my main hobby, cars in general are, but mostly car audio, and home audio for that matter.
ive got 2 18s in my room, and 5 15s in my explorer.
i just like listening to it lol. i also like when friends get in and theyre like "ya i got 2 12's mines loud"
then i play it, and they stfu
pimpedout97x
my dad thinks im crazy lol
Old Jul 15, 2007 | 02:15 PM
btallack's Avatar
btallack
You probably are crazy. But I think that applies to most MINI owners.
Old Jul 15, 2007 | 02:26 PM
pimpedout97x
Old Jul 16, 2007 | 01:54 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Congrats with the new set up...I think you are the loudest mini on the planet...probably a world record for loudness in such a small car.
Old Jul 16, 2007 | 01:55 PM
pimpedout97x
i hope so lol
i want another mini just to throw a wall in with like 6 12's or 2 18s
Old Jul 18, 2007 | 07:12 AM
pimpedout97x
i put the 15 in...its just temporary, my 12 will be just as loud once the permanent box is built, prally louder.
the BACK BUMPER shakes......rear wiper jumps 1.5+" off the window......insane...vids later tonight
Old Jul 18, 2007 | 07:58 AM
PGT's Avatar
PGT
if you are having current issues, that battery will only make things worse. An amp that truly delivers 3000watts needs more amperage than the stock MINI alternator can deliver. The battery is just an additional load on the alternator.
<--- old school 12V audio guy who's built his fare share of high dollar cars for customers and myself
Old Jul 18, 2007 | 08:00 AM
pimpedout97x
i know, and i agree with you
but the battery should hold the current and not drain as fast as the stock battery does, there for the alt will have time to recharge the battery. at least im hoping. a company can build me an alt thats 180 amps....i would like a 250-300a though...
Old Jul 18, 2007 | 08:06 AM
PGT's Avatar
PGT
just be sure to drive around a bit with teh stereo turned down before turning off the car
Old Jul 18, 2007 | 08:25 AM
pimpedout97x
lol!
this company quoted me 435 for them to build a 180 amp alt!!! thats expensive, especially for 180a...if it was 300a it would be more reasonable lol
Old Jul 18, 2007 | 08:39 AM
PGT's Avatar
PGT
where are you located? there's a shop in Manassas VA that will rewind your stock one for higher amperage. Artie's Auto Electric I think
Old Jul 18, 2007 | 08:41 AM
pimpedout97x
im in tampa florida. if you dont mind, if u have the number or your not far from them, could you check on that for me? id have to ship them mine though...
Old Jul 18, 2007 | 08:47 AM
PGT's Avatar
PGT
(703) 361-1717 - don't quote me on the service...I might be remembering them wrong as it's been a few years.
Old Jul 18, 2007 | 09:11 AM
pimpedout97x
ok ill call them up lol
Old Jul 18, 2007 | 10:22 AM
pimpedout97x
he said he doesnt offer any upgrades for a MINI alt :(
Old Jul 18, 2007 | 10:26 AM
PGT's Avatar
PGT
oh well...worth a shot
Old Jul 18, 2007 | 10:44 AM
Greg S's Avatar
Greg S
Hey pimp, I'd agree with PGt here also. The second battery is going to put more of a strain on the system and not really help the amp all that much. Batteries are design for hard long power draws like you get from the starter, not multiple short bursts like you'll be getting from the amp. If you can't find a rewound alternator or an after market unit that can be retroed in then I would opt for a load of capacitors to store power for quick bursts and a quick recharge time. You might want to just look who makes the stock alternator and see what other units they make that have a higher output rating and still have the same bolt patern. I did this one time with an old '89 Eclipse I had. Discovered it was a Delco based alternator and swapped it with a Fosgate dual output 180 amp GM small case unit. I had to refab the mounting arm and space the pivot mount about 1/4" but after doing that it worked great and I never had power issue again. Of course I was only running about 1045 watts RMS, so a little less that what you have, but it was powering 4 10s.
Old Jul 18, 2007 | 10:58 AM
pimpedout97x
i dont like caps, ive found them to not be as good as batteries. my explorer will have 14+ batteries.
the battery i have is designed for large audio systems, its made to hold the charge longer than a regular battery, so it should hold its voltage longer than the stock.
theres numerous people running this amp and other 3k+ w rms amps, with just 1 battery, and no issues. but when im off work ill let yall know if the battery worked.
Old Jul 18, 2007 | 12:53 PM
PGT's Avatar
PGT
an upgraded battery is no substitute for a capacitor. some amps don't matter but your's has an unregulated power supply....a capacitor is a good thing.
Old Jul 18, 2007 | 08:19 PM
pimpedout97x
i dont like them.
the battery is in, it helped out A LOT.
all i need is a higher amperage alternator, and ill be set!
it really did help a TON tho...the voltage doesnt drop NEARLY as bad...
Old Jul 18, 2007 | 08:24 PM
pimpedout97x
i turned down the gain on these vids...if i turn it up, the rear wiper goes CRAZY
the vids dont pick up hardly any of the moving things.... ive got 4 vids, ill post them as they upload.
Old Jul 28, 2007 | 12:59 PM
MotorMouth's Avatar
MotorMouth
Did you start a build thread that grew to like 40+ pages on caraudio.com forums? Your explorer sounds like one I read about on that forum..
