Navigation & Audio R56 DIY Radar Detector Hardwire?
Old Jul 14, 2007 | 07:24 AM
mikeo's Avatar
mikeo
Has anyone hardwired a radar detector into their R56 yet? I could sure use some DIY advice.
Old Jul 14, 2007 | 10:43 AM
Coopaw's Avatar
Coopaw
I just hard wired my Escort into mine last week. I have the remote button wiring adapter. The detector is just velcored to my dash in the left corner by the A pillar. Ran the wires down along the door and under the dash. Put the remote button on the side of the console just behind the shifter. Ran the wiring over to the fuse box and tapped into the Cig liter fuse I think. The hardest part was finding a place for the ground wire. Finally put it under a bolt on the bracket where the steering shaft goes though the firewall.
Old Jul 14, 2007 | 10:49 AM
mikeo's Avatar
mikeo
Thanks. However, I don't have the remote button setup for my Escort 8500 and I was hoping to mount the actual unit up high near the rearview mirror. Has anyone tried tapping into a power source up in the sunroof control/lighting area?
Old Jul 14, 2007 | 10:58 AM
mikeg4572's Avatar
mikeg4572
I tried to hardwire my V1 into the power near the rearview mirror with no luck. What I did was run the wire in the headliner over to the passanger door over the door around to the door sill then to the fuse box. The reason I went around the door was to aviod going down the front window pillar and the airbag in there.
Old Jul 14, 2007 | 04:55 PM
crucial_fiction's Avatar
crucial_fiction
if you undo the sunroof/moodlight controls and drop them down you can route your 12v line into the fat light purple w/blue stripe wire and run the cable out of the headliner behind the rearview mirror.
Don't worry about the detector staying on, it will shut off anywhere from 15-30 minutes after the car is off.
Old Jul 14, 2007 | 06:31 PM
ahalibut's Avatar
ahalibut
Ah, nice! Pics if anyone is able please. I'm a visual learner.
Old Jul 15, 2007 | 05:24 AM
crucial_fiction
I would take some pics but it's really simple, just a flathead to gently pop off the faceplate of the control console, then 2 maybe 3 hex screws to drop the guts of the console and it's the purple/blue stripe wire (it is physically bigger in diameter than all the other wires in the cluster).
Old Jul 15, 2007 | 01:57 PM
crucial_fiction
https://www.northamericanmotoring.co...d.php?t=107415
Old Jul 15, 2007 | 04:56 PM
mikeo's Avatar
mikeo
Originally Posted by crucial_fiction
Thanks! that's exactly what I was hoping for. Very generous of you to take the time and share your knowledge with us.
Old May 5, 2011 | 06:06 PM
reRESERVEDMD's Avatar
reRESERVEDMD
I'm trying to hardwire my system just the same way but every time I try to connect the ground to a metal of some sort, it doesn't work. When I connect it to the cigarette lighter (with power to the 12V cable) it works no problem... Any help? Thank you!
rtk90
Aug 29, 2019 09:08 AM
newowner
Sep 15, 2015 07:18 AM
Sep 4, 2015 01:32 PM
Sep 4, 2015 01:31 PM
