Navigation & Audio glove box stereo install?
Old Jul 12, 2007 | 11:08 AM
darigaaz12's Avatar
darigaaz12
first post here
my cars been ordered and from everything I read you can't take the stock radio/cd player out of the car. Wondering if the glove box is big enough enough to fit an aftermarket cd player. I planned on getting one with a remote...
any ideas? I've done plenty of installs so I'm either going to try this or just hook up an amp to the speakers through the original radio. subs would be hooked up with either choice though
Old Jul 12, 2007 | 12:37 PM
Birdman's Avatar
Birdman
Yes, plenty of room in the glove box, it's actually pretty roomy. BUT, the CD player in the car is fine, why sould you add antoher one?? I understand an amp, replacement speakers, or most importantly a Subwoofer, but a CD player??
Old Jul 12, 2007 | 12:40 PM
Loony2N's Avatar
Loony2N
If you are talking 2007, there is also enough room in the "hidden compartment" if you remove the box they put in if you don't get the cd changer or i-pod adapter.
Old Jul 12, 2007 | 02:53 PM
ramtaajogi's Avatar
ramtaajogi
because he wants to drive that amp w/ a good head unit. Im sure that mini head unit cant compare to an alpine one.
Old Jul 12, 2007 | 03:40 PM
MotorMouth's Avatar
MotorMouth
psst..
The MINI headunit IS an alpine one.
Old Jul 12, 2007 | 05:34 PM
darigaaz12's Avatar
darigaaz12
Originally Posted by MotorMouth
psst..
Must be a lower end model than
I'll be swapping all speakers and adding a sub or two probably, lil metro I have right now has two 12's
Thanks for the info on the compartment behind the glove box. I'll take a look into that when I get the car can't wait!
Old Jul 13, 2007 | 02:46 PM
mmccartha's Avatar
mmccartha
did you get nav. if you did go with the alpine oem integration system they have it will basically be an aftermarket head unit expect for the screen. if you didn't get nav, you could always go with an audio control DQL-8. just throwing out some ideas
Old Jul 13, 2007 | 02:50 PM
MotorMouth's Avatar
MotorMouth
The stock head unit is actually pretty good. Sure you don't have RCA pre-outs which would be best but with a good high-low converter all but audiophiles will never be able to tell the difference.
I'm running the stock unit with aftermarkets amps and speakers and love the way it sounds. If you want all the phase change and eq options that some headunits offer just go with something like a RF 360.
Old Jul 13, 2007 | 06:57 PM
darigaaz12's Avatar
darigaaz12
I'm open to ideas, I could use the stock HU but I wanted to be able to use mp3 disks and the standard HU doesn't play those I don't think....nvr looked into "an audio control" ill check that out though, still a month and a half until I get my car probably anyways
Old Jul 13, 2007 | 07:02 PM
Volker's Avatar
Volker
psst..
Really ? I thought they are Becker (HK) ? At least the one in my 2006 MCCa looks a lot like the one my F-i-L had in his 530...
Old Jul 13, 2007 | 07:04 PM
Volker's Avatar
Volker
sorry, you were talking about the new ones... my mistake.
Old Jul 13, 2007 | 07:58 PM
rattmobbins's Avatar
rattmobbins
psst..
I didn't know that!!! Cool. Any idea what speakers they use in the HiFi? I know the high-end speakers in the R53 were Harman Kardon, but what does the R56 use?
Old Jul 13, 2007 | 08:46 PM
jrunner192's Avatar
jrunner192
The new head unit does actually play mp3 disks if that is of interest to you.
Old Jul 14, 2007 | 08:28 AM
darigaaz12's Avatar
darigaaz12
I thought the hifi upgrade was the only system that plays mp3s, if not that opens up a bunch of choices o things I could do....
Old Jul 14, 2007 | 09:55 AM
MotorMouth's Avatar
MotorMouth
the head unit is exactly the same in both systems.
adrchn
Aug 13, 2019 02:11 AM
blackie
Aug 23, 2015 08:44 PM
Chasp
Aug 22, 2015 01:26 PM
