Classic Mini wiring harness
Old Jul 8, 2007 | 11:13 PM
MustBird's Avatar
MustBird
I have a 1962 Austin Mini and the wireing is starting to fail all over do to it being old and the crappy repair work done by previous owners. I was wondering if anyone has knows about any really good new wireing harnesses. I know that Mini mania sells some but all the pictures are the same and there are no descriptions. Any help would be greatly appreciated.
Old Jul 9, 2007 | 07:39 AM
minimk3's Avatar
minimk3
You can always call Don from Minimania. They are great folks and I am sure that they would be able to help you find the right harness.
Old Jul 9, 2007 | 10:50 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
Chris, if you want, I can see what a harness would cost in Aus if you can wait till September for it.
Old Jul 9, 2007 | 10:51 AM
elprofe's Avatar
elprofe
first thing to do is to make sure you have a real 62 so you can get the right harness. Call Doug at www.heritagegarage.com and he'll help you ID it.
original style harnesses are a bit pricy, but they are the easiest to install.
If you are good with elecrical systems, you can get an aftermarket harness from your local hotRod shop under 200 bucks and DIY.
Old Jul 9, 2007 | 11:17 AM
Agro's Avatar
Agro
His car is certainly a real 62. It's had a few changes made to it (5-speed gearbox springs to mind) but it is a beautiful car. Sliding windows and all.
Old Jul 9, 2007 | 11:41 AM
dragonflyer's Avatar
dragonflyer
Get a Painless kit like this one. http://cgi.ebay.com/ebaymotors/EZ2Wi...spagenameZWDVW
Get rid of the Prince of Darkness and all your problem will go away
Old Jul 9, 2007 | 12:28 PM
elprofe's Avatar
elprofe
22 CIRCUITS IS too big for a mini. 13 circuit harnesses have less wires.
Old Jul 9, 2007 | 02:00 PM
dragonflyer
That was just to give you an idea. the guy that makes those can make custom ones too if you contact him.
Old Jul 9, 2007 | 03:34 PM
Minimad's Avatar
Minimad
Save the grief. Buy a correct replacement original (esp for a 62 Mk1 Mini). Changing the harness will devalue your Mini somewhat. I say this only cuz it is an early Mini. If it were a Mk3 on, who cares...
The "Prince of Darkness" stuff is much overrated...
Old Jul 9, 2007 | 08:54 PM
L1LABRAT's Avatar
L1LABRAT
I agree, Heritage is where I get nearly all my parts. Exceptional customer service. Better to get a replacement factory harness or you'll spend hours and hours trying to figure out odd little things.
Old Jul 10, 2007 | 06:45 AM
IanF's Avatar
IanF
Since the car appears to have been modified, I would go with a hot-rod type harness. Painless sells a dizzying array of harness options.
I am in the middle of replacing the wiring harness in our '79 Spitfire. We went with a aftermarket harness specifically designed for the car, which has it's positives and negatives.
On one side, the wiring colors mimic the OEM design, so connections have been relatively easy.
On the downside, the fuse/relay block is huge and fitting it in the car was very difficult. For this reason alone, I've wondered if we should have bought a hot-rod harness (available in "compact" models) instead...
The guy is apparently a retired electrical engineer who builds the harnesses in his spare time for a number of British cars. Unfortunately, he seems to have sized the wiring per NEC which while fine for a house, is massively over-engineered for an automotive application. As a result, routing the wires through space originally designed for wires half the size has proved at times... challenging...
Old Jul 10, 2007 | 08:57 AM
elprofe's Avatar
elprofe
IF you go EZ wiring route, get the one with the least circuits and is labeled every five inches. YOu'll save time and frustration by not referring to the diagram as much.
Old Jul 10, 2007 | 11:50 PM
MustBird's Avatar
MustBird
That would be awesome agro and thanks everyone for the help. I am thinking of converting it to a negitive ground so that will help with the wireing. Again thanks everyone for the help
Wohnson89
Jun 10, 2020 04:53 AM
Dec 23, 2015 10:36 AM
tr3y003
Oct 22, 2015 10:48 AM
DWooderson
Aug 10, 2015 09:12 AM
nismo4life
Aug 5, 2015 08:31 AM
