Brake Job question
Old Jul 5, 2007 | 11:56 AM
gary442's Avatar
gary442
Brake Job question
Getting ready to do a rotor and brake pad replacement on my 03 MCS...pulled the wheel of to see what I was in store for and saw the torx fitting that holds the rotor on...as a test I tried to loosen it but I assume it's frozen/rusted on....any tips on getting this thing off ? Also, can I assume it's a standard left-to-loosen bolt ? thanks
Old Jul 5, 2007 | 11:59 AM
snid's Avatar
snid
For that torx bolt, you can either be patient and use lots of PB-Blaster / Liquid Wrench / etc. Or, just use / find an air powered impact wrench and break the bolt head off. If the break is clean enough, no damage done. All four of mine have been broken off.
Old Jul 5, 2007 | 01:10 PM
hemiheaded18's Avatar
hemiheaded18
Yeah, just break it. You don't need it. Its only on there so the factory dosen't have to pay someone to hold on the rotor while the wheels go on. I've busted 3 out of 4.
Old Jul 5, 2007 | 01:24 PM
Xiek's Avatar
Xiek
or heat it a bit to loosen it if you have the equipment.
Old Jul 5, 2007 | 01:32 PM
Crashton's Avatar
Crashton
PB Blaster & hit it with an impact. An impact driver with the correct torx bit should do it. When you put them back in use anit-seize.
Old Jul 6, 2007 | 11:34 AM
SteveS's Avatar
SteveS
I just did my brakes on 03 MCS. I'm in SoCal so do not get any salt and little rain. In anticipation of torx screw removal problems, I had been PB blasting them when I would take the wheels off to rotate or whatever. The Torx screws were real easy to remove. If you are in no rush, just PB blast a few times and allow it to work its way in.
Old Oct 27, 2007 | 06:43 PM
mcs22004's Avatar
mcs22004
I will have to give this a try. I would love to rip those heads off instead of having to drill them. I went after one today with an impact-grade T-50 bit attached to a 1/2 drive socket and destroyed the T-50 bit in seconds. The Torx impression in the bolt head looks unharmed. Even worse, this particular rotor retainer bolt is about two years younger than the other three because I had the hub replaced last year.
Old Oct 27, 2007 | 08:29 PM
kapps's Avatar
kapps
Kroil and/or heat will be your friends.
sevin
May 2, 2026 06:11 AM
W0TM8
Dec 19, 2019 07:50 AM
thebordella
Aug 31, 2015 01:37 PM
ShadyCoop
Aug 24, 2015 06:05 AM
nomar116
Aug 10, 2015 11:24 PM
