R56 RFI / Turbo wind down after engine turned off?
Old Jul 3, 2007 | 03:28 PM
Hogtied's Avatar
Hogtied
Once again, did a search - no luck finding an answer.
Rumor control has it that it's a good idea to let a turbo-powered car idle down for a couple minutes after a drive. The purpose is supposedly to allow the turbo to spool down, so it won't bake after the engine is turned off.
I know that to be true in some diesel powered trucks, but I've never read or heard anything related to similar procedures with the Mini. And, for what it's worth, my sales guru didn't mention anything about letting it idle down during my delivery...
An old wive's tale, perhaps?...
Old Jul 3, 2007 | 03:36 PM
emtrey's Avatar
emtrey
that is why your fans continue to run after shut off...no need to do anything more.
Old Jul 3, 2007 | 03:57 PM
SimpsonGI's Avatar
SimpsonGI
Coordinator :: Emerald MINI Car Club
There have been posts that I've read about this and from what I remember reading the Minis have a built in system that will keep cooling the turbo after its shut off. Supposedly there isn't a need for a cooler but I suppose that would depend on your own opinion and comfort level.
Old Jul 3, 2007 | 04:13 PM
justaguyinvegas's Avatar
justaguyinvegas
When turbo-equipped cars first came out, they recommended idling the car for a minute to allow the turbo to cool so it doesnt bake the oil that gets trapped when the oil pump stops. This was an early design problem. All modern turbo-equipped cars no longer have this problem since they have systems that keep the oil from being trapped in a high-heat environment.
Old Jul 3, 2007 | 09:35 PM
karlInSanDiego's Avatar
karlInSanDiego
The R56 uses an auxillary water pump (electric) to continue to circulate water through the turbo after you shut the car off. MINI's turbo is both water AND oil cooled, but it can't pump oil after shutoff as that's a mechanical pump driven by the engine's movement.
Old Jul 3, 2007 | 09:57 PM
dwjj's Avatar
dwjj
Drewmom posted some in depth info if you're interested on p2 of this thread
https://www.northamericanmotoring.co...t=91756&page=2
Old Jul 4, 2007 | 03:29 AM
Hogtied's Avatar
Hogtied
That's the answer I was looking for.. thanks for the link.
09R56
Nov 16, 2022 10:49 AM
damncajun
Aug 17, 2015 08:25 PM
AZN Optics
Aug 16, 2015 11:52 PM
TheAlterKocker
Aug 13, 2015 12:25 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
