Falken Ziex Ze 912 or Toyo Proxes Tpt
If they're not available in 195/55-16 you should go 205/50-16.
The Falken tires have higher customer ratings at 1010tires.
The Toyo Proxes 4 is a better tire than the Toyo Proxes TPT.
What are the benefits of 195/55 vs. 205/50?
195/55-16 is OEM size.
205/50-16 is the size most people choose when replacing runflats with conventional tires. They offer a wider contact patch and there are a lot more choices in this size.
Sizes that fit-
195/50-16 fits rims 5.5-7" wide 23.7" tire diameter (much smaller than stock)
195/55-16 fits rims 5.5-7" wide 24.5" tire diameter (stock sized)
205/50-16 fits rims 5.5-7.5" wide 24.1" tire diameter (smaller than stock)
205/55-16 fits rims 5.5-7.5" wide 24.9" tire diameter (taller than stock)
Smaller tires register slightly higher speedometer and odometer readings and can wear a little faster. Lower profile improves sidewall stiffness and improves handling while wider tires usually weigh more but offer a little better handling. Taller tires are more comfortable for street use. 205/55-16 and 205/50-16 are very popular sizes for stock 16" rims.
In 195/50-16 (the original size in question)
Toyo Proxes Tpt (High performance All Season tire)
400 treadwear V speed rated 19 lbs about $89 each (might be sold out)
Falken Ze-912 (Ultra high performance All Season tire)
360 treadwear V speed rated 20.2 lbs about $86 each
Toyo Proxes 4 (Ultra high performance All Season tire)
300 treadwear V speed rated 18.5 lbs about $68 each
In 195/55-16 Falken Ze-912 ($89 each) is sold out.
In 205/50-16
Falken Ze-912 $85 360 treadwear V speed rated 21.6 lbs
Toyo Proxes 4 $80 300 treadwear V speed rated 20.5 lbs
Toyo Proxes Tpt $92 for V speed rated 400 treadwear 21 lbs
In 205/55-16
Falken Ze-912 $81 360 treadwear V speed rated 22.8 lbs
Toyo Proxes 4 $77 300 treadwear V speed rated 20.9 lbs
Toyo Proxes Tpt $89 for H speed rated or $98 for V speed rated 400 treadwear 21 lbs
In 205/50-16
In 205/55-16
Sizes that fit-
In 205/50-16
In 205/55-16
In 205/50-16
In 205/55-16
vbmike
Oct 15, 2015 04:32 AM
slitcher
Sep 7, 2015 06:17 AM
slapey
Tires, Wheels, & Brakes
Mar 26, 2004 07:51 AM
