R50/53 service engine light!?
Old Jun 26, 2007 | 02:46 PM
minipooper02's Avatar
minipooper02
My brother has some baddddd luck.
he got his mini back in ship shape and now he has a service engine light come on in his mini s and it says
P0441
-Evap Emission Control System Purge Flow Fault-
Some one please help us.....
Old Jun 26, 2007 | 04:35 PM
BBCooper's Avatar
BBCooper
I was curious on this one since I have not seen this code before in posts...
I did a search and found this link to a nice document (ok it is for a truck - but it covers the basics pretty well)..
One solution for this code.. check the gas cap.. see page 3..
if that is the case. I think the MINI will turn off the error light after so many "good" engine starts... Or you can use a scan tool to clear the code and see if it returns (indicating that it might not be the gas cap.. )
I guess question back to you.. what was the MINI being fixed for?? .. That might shed some light on why the Check Engine Light tripped on..
Good luck
Old Jun 27, 2007 | 08:06 AM
nethack's Avatar
nethack
Minipooper02
I had the "Service engine Soon" light come on recently for no reason I could figure out. Took the car to the dealer and they put the gas cap back on correctectly: boy was I embarrassed! Has something to do with proper fuel tank venting. The dealer tells me that once the gas cap is restored to its proper fit the light will go out by its self in approximately 40 drive cycles.
Although it was embarrassing, I'm glad I took the car to the dealer. They reset the light all fixed. I hope this helps and you get your problem solved.
Cheers
nethack
Old Jun 27, 2007 | 05:54 PM
hegira's Avatar
hegira
Both AutoZone and Advance Auto will scan, and reset the check engine light for free.
Old Jun 27, 2007 | 09:51 PM
Gromit801's Avatar
Gromit801
But not in California where it is illegal for them to do so.
Old Jun 28, 2007 | 05:08 AM
hegira's Avatar
hegira
It's illegal to check it or reset it?
Old Jun 28, 2007 | 05:23 AM
03BRG's Avatar
03BRG
To reset it.
Old Jun 28, 2007 | 05:49 AM
minipooper02
Originally Posted by 03BRG
To reset it.
they wouldnt reset his either... They checked it and the guy said "We arent allowed to reset these newer french cars they might lock the system from a foreign signal trying to mess with the computer." My brother then mad as hell said "its British not french you idiot."
Old Jul 2, 2007 | 07:43 PM
moodylewdd's Avatar
moodylewdd
I have done the gas cap thing, and a totally different light came on. The other light was on the Speedometer, and actually says 'check fuel cap'. I did, and restarted the car-it went out. (That was a couple months ago).
Now...my check engine light just camr on today ('02 MSC w/ 41,000+ miles). I am really far from the dealer, so you think Autozone will check it for me? My husband has about 8,000.00 worth of scan equipment from Snap-On, and nothing to read my car! The car seems to run out normally, hope its nothing serious!
Old Jul 3, 2007 | 04:43 AM
hegira's Avatar
hegira
Re-fueling with the engine running can also throw a CEL.
Offer the AutoZone guy a 10-spot.
Old Jul 3, 2007 | 06:03 AM
R56MINICooper's Avatar
R56MINICooper
Sounds like a leaky gas cap. I had this happen on my Mazda and it had to have the gas cap replaced as it was leaky. (Of course I also had it throw the same CEL for the PCV so it could be that too)
Old Jul 3, 2007 | 08:09 AM
moodylewdd's Avatar
moodylewdd
Hey thanks, I will do that. I hate when warning lights of anykind are on. Its bad enough I drive around with the airbag light on, 'cause I cant get down to the dealer for a couple more weeks for them to re-wire it. Appreciate the input!
Old Jul 3, 2007 | 08:22 AM
Gromit801's Avatar
Gromit801
AutoZone told me flat out they aren't allowed by the BAR to check the codes at all in California, can't even plug in the code reader for you. Garages have been raising hell about them stealing business. Typical.
Old Jul 3, 2007 | 08:23 PM
moodylewdd's Avatar
moodylewdd
Thats awful. I mean for a few dollars you can buy your own code reader right? Are they going to try and prevent the sales of those next???
Old Jul 3, 2007 | 08:34 PM
Gromit801's Avatar
Gromit801
To be honest, I'd rather check it out myself. The idiots I've met at the AutoZone around here don't fill me with enough confidence to correctly identify my car if they were looking right at it from two feet away.
Etrain
16
Aug 5, 2024 04:37 AM
09R56
Nov 16, 2022 10:49 AM
W0TM8
Dec 19, 2019 07:50 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
