Road Racing Discussion Interested in taking your MINI road racing? Find out what you need to do to get your MINI ready!
Toyo RA1 track tires
Old Jun 20, 2007 | 05:27 PM
newbs49's Avatar
newbs49
Is anyone using Toyo RA1 16 tires for track use. If so what size? Any rubbing issues. Thanks
Old Jun 20, 2007 | 07:04 PM
RED FURY's Avatar
RED FURY
Not 16 but
I use 205-17-40 Toyo RA1 shaved, not even close to rubbing anything
They are small
PS: I'll be in Tonawanda for the 4th of July week, sans MINI
Maybe you can drive your car down to the Canal for one of the concerts ?
Phil
Old Jun 20, 2007 | 08:14 PM
newbs49's Avatar
newbs49
Thanks Phil
I really need some info on 16's before Mosport next month. I need to replace my Kumho's before then and not sure which way I'm going on sizes or tires.
RA1's do seem to last. Let me know when you get in town.
Old Jun 21, 2007 | 03:14 AM
J Propane's Avatar
J Propane
Larry,
When are you at Mosport?
Old Jun 21, 2007 | 04:10 AM
snid's Avatar
snid
If you get an answer through PM or other sources, let us know what it is. Or let us know what choice you make on your own. I'm in the same boat. My track wheels are 16", and the choice of what RA1 size is not obvious.
Old Jun 21, 2007 | 04:45 AM
onasled's Avatar
onasled
how wide are your wheels guys?
Old Jun 21, 2007 | 04:56 AM
cristo's Avatar
cristo
Alliance Member
It looks like 205/55/16 is the only size that would fit.
They're a little taller than stock, but pretty close,
so might rub a little on a lowered suspension.
Many people do use this size on street cars.
http://www.toyo.com/docs/tires/produ...category=sport
Old Jun 21, 2007 | 06:16 AM
snid's Avatar
snid
Greg,
I've got 16"x7.5" +43 offset.
205/50 would be safe as far as rubbing goes, but narrower and taller than optimal.
225/50 - not much shorter, possibly too wide.
245/45 - gotta be too wide, right? Even if it fits, I wouldn't need that much rubber.
Old Jun 21, 2007 | 09:23 AM
blalor's Avatar
blalor
Since when has "need" had anything to do with it?
I ran 225/50/15 Yoko ES100s on Konig Rewinds last year. Only *very* minor rubbing in the rear at full suspension travel. Stock suspension. Just a little anecdotal evidence that the width'll work, at least.
Old Jun 21, 2007 | 02:25 PM
newbs49's Avatar
newbs49
Greg
16x7 205-55-16 looks about it. Taller but not a bad thing.
Alain
July 16-17 GVC - BMWCCA
Greg
Where did you get your Toyo's from?
Old Jul 2, 2007 | 10:38 PM
bluesmini's Avatar
bluesmini
The RA-1's are OK but..... there is a better cheaper tire.
The NITTO NT-01 is the same compound as the RA-1 but with bigger tread blocks, stiffer sidewalls and they are cheaper than the RA-1's
Since our cars are front drive we wear them out quick. I can get 3 days out of a set of RA-1's and 11 days out of a set of NITTO's.
check them out.
www.discounttiredirect.com
not the regular discounttires.com.
Old Jul 3, 2007 | 03:47 AM
onasled's Avatar
onasled
Originally Posted by bluesmini
....... I can get 3 days out of a set of RA-1's ......
Hmmm, ... never heard this before. In fact quite the opposite. My RA1s lasted forever. In fact they only really started to get real good after 3 days of the Glen. Are you getting them shaved? If not then yes, they get sloppy with full tread after 3 days maybe. Overheat too much.
How are they going bad?
Old Jul 3, 2007 | 07:19 AM
bluesmini's Avatar
bluesmini
Here are my thoughts on your tire wear vs mine.
My car is factory weight. The only thing i've done to make it lighter is wheels. Other than that it's a pig of a car. It's the front left tire that takes the beating on my car. Since the RA-1's are directional with tread I can only rotate front to back. The Nitto's are inside outside specific I rotate them around the car giving the hardest working corner a break. Also, the Nitto's are molded to 6/32's instead of 8/32's so no need to get them shaved. That's even more saved $$$ not having to shave them.
Give them a try
Pretty new tire and popular sizes are often back ordered. the 205/40/17's have always been around.
Old Jul 3, 2007 | 07:29 AM
newbs49's Avatar
newbs49
I start this about 16's and hear about 17's. Nitto's are great but no 16's.
Old Jul 3, 2007 | 07:44 AM
bluesmini's Avatar
bluesmini
You're right, only one 16" available for now. Check every so often. It's a new tire. Last year they only offered half the current selection.
Old Jul 4, 2007 | 02:58 PM
onasled's Avatar
onasled
205-40-17 For Sale
https://www.northamericanmotoring.co...64#post1609364
Old Jul 4, 2007 | 04:19 PM
bluesmini's Avatar
bluesmini
gimme
Old Jul 5, 2007 | 06:10 AM
asodestrom's Avatar
asodestrom
snip . Since the RA-1's are directional with tread I can only rotate front to back. T snip.
RA-1's are directional but it only matter in the wet. You can use them either way on dry tracks. AIM tires at Infineon told me this.
Old Jul 5, 2007 | 09:54 AM
meb's Avatar
meb
And that's absolutely true. I rotated my tires before every afternoon session...I even ran them in the rain once backward for goofs and giggles...I would have been faster had I not known they were backward...
Rennfahrer555
General Discussion
38
Nov 1, 2022 03:04 PM
Waszak
Oct 21, 2017 05:55 PM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
eatsleepautox
Oct 30, 2015 06:46 AM
Dashdog
Aug 10, 2015 06:17 AM
