Suspension Suspension travel
Old Jun 13, 2007 | 08:23 PM
tsprayfhs's Avatar
tsprayfhs
Suspension travel
Does anyone know what the total suspension travel is for a stock MCS? In particular the travel under compression would be of great interest. Thank you foryour help.
Motor on
Old Jun 14, 2007 | 03:53 AM
satay-ayam's Avatar
satay-ayam
"not enough"
The stock dampers only have a stroke of about 4". The suspension probably settles at least an inch under the weight of the car, and bump stop is about an inch and a half long. That leaves maybe 2" of compression before the bump stop is really kickin'.
Some of the guys have taken apart their suspension and thought about this a lot more than I have, you might get a more accurate number than that - but I think 2" is a pretty good ballpark number.
Old Jun 14, 2007 | 05:40 AM
meb's Avatar
meb
...and to clarifiy...the stock bumpstop is an active part of the suspension. These do not work soley to keep things from banging into one another.
Roger - you moved in? I lost your number AGAIN!
Old Jun 14, 2007 | 03:00 PM
kenchan's Avatar
kenchan
on stock dampers i cant bear to think going any lower than the h-sports.
even with h-sports the stroke is not enough over larger bumps.
another reason why im running 50 profile tires.
Old Jun 15, 2007 | 04:18 AM
satay-ayam's Avatar
satay-ayam
Yep, pretty much moved in, but not unpacked. What a mess. I'll PM you the contact info...
Old Jun 15, 2007 | 05:34 AM
meb's Avatar
meb
Well, as of last night, My cae - with exception of the Webb Rear swaybar - is now all stock. Suspension travel is again a wonderful thing!
Old Jun 15, 2007 | 02:33 PM
kenchan's Avatar
kenchan
^^ going back to the simple times, i see.
i think im going to order me up a FSD in a couple of weeks.
vulkandino
Oct 31, 2015 08:29 PM
Fourflys
43
Oct 20, 2015 09:42 AM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Emnotek
Sep 29, 2015 07:37 AM
