Interior/Exterior Rear fogs
Old Jun 8, 2007 | 07:58 AM
amazonracer's Avatar
amazonracer
Rear fogs
Has anyone added the rear fog lights light the factory install. I didn't get them and now I think I want them. If there pre-wired and it looks like there is a cut out in the mesh, or no. I haven't actually seen my car yet.
Old Jun 8, 2007 | 08:23 AM
Mike02MCS's Avatar
Mike02MCS
I had the rear fog activated a few years ago at Scottsdale MINI. Seems like it was a little over $100. The installation of a new toggle bank was about all it took. There's only one fog light in the back.
Old Jun 8, 2007 | 09:29 AM
humcmcel's Avatar
humcmcel
I have an '05 cabrio that I added the oem rear fog light too myself. The light bulb and all was aless than $20, the dash switch panel that has to be replaced so you can turn it on was about $75 and it cost $55 to have the dealer program it so it would come on.
Old Jun 8, 2007 | 09:36 AM
MBR's Avatar
MBR
I guess I'll play a trick and just add the rear fog lamp.. No new switch panel, and no $50 fee... Now, where should I purchase from?:impatient
Old Jun 8, 2007 | 10:07 AM
rkw's Avatar
rkw
You can replace the rubber plug with a lamp and make it do something even without doing the whole rear fog thing. It only requires installing a wire jumper in the harness near the tail light.
This kit uses a white lamp that works as an extra reverse light: http://minspeed.net/MMBUL.htm
This kit uses a red lamp that works as an extra brake light: http://minspeed.net/MMBLK.htm
Dec 23, 2015 10:36 AM
I_drive_slow
Aug 18, 2015 10:47 AM
Powershift
Aug 16, 2015 05:14 PM
