Retrofit OEM OBC
well, I don't know if the '05 has the right stalk. To tell, it will have a little button on it, on the top with a little picture that some what resembles a computer. Also if you have the little screen in the Tach. these are the two things you can tell from in the car.
If you have both things, head over to you local (or not so local) mini dealership, and tell them to retrofit the OBC. They may look at you funny so be sure to bring the "OBC Retrofit Manual" . It should take no longer then 10 min.
Then have fun. It cost me $50~ but there are some people around here that got it fro free.
The 05 definitely has the same stalk, all MINI's do but without the OBC it just gives you either speed or outside temp.
You said it cost 50 bucks, was that just for the part cos the labour appears to be a couple of hours.
that was just labor. no parts were needed for my car. Not all Minis have the correct stalk. It you have the button, with the display (only speed and outside temp). then just go to your dealer and have them program it in.
I just had my dealership enable the OBC on my MINI yesterday. I love it and they didn't charge me anything because i had them do it whilst they were doing some warranty work anywhere. I already had the correct stalk.
Wow, news to me....never saw a car with an OBC button that didn't have the proper coding for it.??? If you need the correct switch that has the OBC button, PM me for one cheap.
Chad
Chad
It's not setup so that you can pick what is displayed. It's all or nothing. You can have it programmed, you just need to be sure that you have a button and the display. Some one did a write up on how to do the hardware part on your own, then just have the dealership program the computer.
Chad
OBC for free !!!! =)
I just got back from MAG MINI in Dublin Ohio. My car was in for it's service #1 appointment. I asked if they could do the software part of the OBC retrofit. I'd printed out the instructions & gave them to Doug. To tell the truth I thought it wouldn't be done for some reason or another.
When I picked the car, up yes it was done (N/C)!!! Man am I happy.
Doug Cochran & MAG earned all 5's today.
I just got back from a similar experience at the dealer today. I got my used 06 MCS a week ago, and took it in to have my preferences encoded (key, speed-sensitive washers, etc.) I brought in the instructions for the retrofit kit, told them I had all of the hardware, and asked if they could switch it on for me. This was my first experience at this dealer.
A few minutes later, they said they could do it, and they didn't charge me! I think it might have been their first time doing one, but the key was to have the section of the instructions entitled "coding" handy for them to use. And to throw yourself on their mercy.
bonmot
bonmot
Silly question.....
Is there a "cutoff" on the ability to upgrade? Sounds like '05's and 06's can be done if you have the hardware.... I have an '04 MCS with temp and speed. Anyone know if this is "upgradable"?
I have the button on the stalk ..
but when I called Mini of San Antonio.. they flat out told me that unless my car came from the factory with the premium package that it could NOT be done ..
Anyone know of a Mini dealership in TX that will do the OBC programming ?
I don't know whether it will help the dealer who already refused you see the light, though.
Print this off & take it with you. Point out step 8. to them.
What you need is here>>>> http://motoringfile.com/howto/OBC.PDF
