Need to ID a part.
Old Jun 2, 2007 | 09:57 AM
skydrol's Avatar
skydrol
Need to ID a part.
Found this under the left firewall near the rad of my 1974/90 mini, no tubing was connected to it except the wire connection. when powered up it clicks. Thank for any help
Old Jun 2, 2007 | 11:46 AM
Minimad's Avatar
Minimad
DOn't know, but conjecture that since the plastic outlets aren't barbed or ridged it is likely not part of the cooling system, but part of the pollution control system piping. A valve control by another sensor in the system.
Old Jun 4, 2007 | 11:06 AM
Tall Mini's Avatar
Tall Mini
Could it be the inertia switch? Would have been wired inline of the fuel pump to cut power in a accident? Honestly just guessing
Old Jun 4, 2007 | 11:07 AM
Loony2N's Avatar
Loony2N
Looks like a miniature still to me....
Old Jun 4, 2007 | 05:13 PM
minimk3's Avatar
minimk3
Can you try and check if your windshield washer works? It may well be a washer pump that is remotely installed.
pics from http://www.ukclassicminiparts.com/shopexd.asp?id=408
Old Jun 4, 2007 | 07:05 PM
boom's Avatar
boom
It's not a pump, but a valve of some sort. We just can't figure out what system it belongs to, since it was disabled already. The windshield washer pump is accounted for on the reservoir.
Old Jun 4, 2007 | 07:31 PM
minimk3's Avatar
minimk3
Do you have Air conditioning? Carb or Multipoint injection?
Though I've never seen it in a mini it may also be an idle-up solenoid (I am not sure if that is the right term for this part)
I know from older japanese cars (carburated) they have an idle-up solenoid valve that is tied to a diaphragm that is connected to the carburator's throttle mechanism. Its purpose is to use vaccum to mechanically "pull" the throttle whenever the AC compressor turns on and increase engine idle rpm.
Old Jun 4, 2007 | 08:31 PM
boom's Avatar
boom
No A/C..... Carbed engine.
Old Jun 5, 2007 | 07:24 AM
minimk3's Avatar
minimk3
I am out of ideas.... I hope you'll find out what the part is for soon.
dinomaniac
Sep 18, 2018 04:19 AM
navybsn
R55 :: Clubman Talk (2008+)
Dec 29, 2015 12:32 PM
LordOfTheFlies
Oct 19, 2015 05:02 PM
daviday
Sep 25, 2015 01:31 AM
Grizld700
Sep 2, 2015 04:59 PM
