Latest Stealth VacuCam Camera Mod--OctaneGuy
Hey folks,
Thought I'd post a little teaser of what I've been up to lately. Since news and updates on VacuCam products have been on vacation for quite awhile, thought I'd post what I did for a permanent rear camera. I utilized an area that was useless on my MINI and made it functional. Yes it's a little off centered--I just need to adjust the ball mount a bit.
Don't look for this to be available anytime soon though--this is just one of my experiments that will probably never become a product.
To make it stealth again, I just pop the little cover back on. I might just make a tinted panel here one day.
Do you see it??? More details later if interested.
Richard
Richard
Hahahahahaha..ouch! Well it's kind different. LOL
And now a shot of my front camera mount--mounted on my modified "Blair No Hole Front License Plate Mount (BNHFLP), with Bar10Girl posing alongside my MINI from yesterdays c3 club run. Wires ran under bonnet, no taping necessary and no huge bundle of wires needed. I just ran with two cameras--front and rear, and worked out perfectly. Audio was a small mic ran through the firewall.
Now a short video clips showing front and rear camera in operation.
Flash version
http://www.littlemini.us/files/c3_re...lson_short.swf
Windows Media version
http://www.littlemini.us/files/c3_re...lson_short.wmv
Sorry no Quicktime
video clip has been sized to 320x240 and best quality is on the Windows Media version.
Richard
Richard
Flash version
Sorry no Quicktime
Richard
Richard
The mic is mounted right in front of the Alta intake--so you're hearing the air rushing into the intake combined with the super charger whine. I mounted it low to avoid the wind buffeting that rushes in from the scoop--but still not the best place for mic placement on the S.
Richard
Richard
you should get a remote mic set up for it because it sounds like bad wheel bearings or some metal on metal terribleness. just my 2 cents. pictures quality is quite good and it doesn't seem to shake too much either.
It is a remote mic. Not exactly sure what you're saying. But mic placement is key. There are some pretty funky sounds under the bonnet that are very "unMINI like" ---whirring of belts, clicking sounds, etc... when from the outside all you really hear is the super charger whine and exhaust and maybe the intake.
I've listened to this clip a dozen times and still not hearing this "metal on metal terribleness" you are referring to.
Thanks.
Thanks.
I don't hear the metal sound either- just the SC and trans whine and the sucking air from the alta- good quality video it almost looks like you stabilized or gimbled it in some way. The mic is going to be a tough nut as you mentioned a lot of wierd noises are going on under the bonnet.
Thanks for verifying that I'm not crazy.
Yeah, it IS stabilized. I turned my MINI into a very large dolly!
That's always been the premise of my VacuCams. Rigids mounts with light cameras--solidly connected to the MINI will produce "floating" shots. Thanks!
That's always been the premise of my VacuCams. Rigids mounts with light cameras--solidly connected to the MINI will produce "floating" shots. Thanks!I don't hear the metal sound either- just the SC and trans whine and the sucking air from the alta- good quality video it almost looks like you stabilized or gimbled it in some way. The mic is going to be a tough nut as you mentioned a lot of wierd noises are going on under the bonnet.
It appeared to me that there was a small bit of digital artifact just in front or behind the car as it was moving. Is it just my internet connection or am I seeing things (which is always a good possibility)?
There actually is quite a bit of artifacting in these clips. They are resized from 720x480 down to 1/4 the resolution, and highly compressed. Any artifacting that was captured on the original tape will be the fault of the miniDV format which isn't kind to extremely detailed, fast changing footage.
Richard
Richard
dutchhome
Sep 30, 2015 07:17 AM
R53UndaPSI
Sep 21, 2015 09:42 AM
atlantaorange
Sep 16, 2015 12:43 PM
