Suspension So Easy Even batgirlwildcat Can Do It!
Old May 30, 2007 | 04:02 PM
batgirlwildcat's Avatar
batgirlwildcat
I personally installed Malibu Stacy’s first suspension mod, custom anodized strut tower reinforcement plates from Way Motor Works. Perhaps you saw them on display at MOTD…
Using a 13mm socket and 3/8 wrench, I first loosened the three bolts...
and removed them by hand, being careful not to drop them down the engine bay.
Then I prepared the area by wiping off all the dust…
and laid the passenger-side plate in place, M7 side up.
Next, each of the bolts was set back in…
and hand threaded until tight. I followed that up with the torque wrench, tightening until it indicated that 25 ft lbs of torque was reached (click!).
Then I polished up the pink…
and repeated the same procedure on the other side.
Now Malibu Stacy has some beneath-the-bonnet bling to show off! Jealous? Go get your own.
Tools required:
- 13mm socket
- Socket wrench
- Torque wrench 0 – 25 Lbs
- Shop rag
Approximate time from start to finish: 5 minutes
Thanks to Way and Matt for the pink plates, and to Ed for supervising, photographing, and contributing to this complex and highly technical write-up.
Old May 30, 2007 | 04:04 PM
chows4us's Avatar
chows4us
Woot
NICE!!!
Old May 30, 2007 | 04:11 PM
irieman's Avatar
irieman
Originally Posted by batgirlwildcat
I personally installed Malibu Stacy’s first suspension mod, custom anodized strut tower reinforcement plates from Way Motor Works...
Nicely done! We certainly could use more write-ups featuring the Women of NAM! Y'know- for... the diversity. Yeah. Diversity.
Old May 30, 2007 | 04:12 PM
ChrisW's Avatar
ChrisW
Brains looks and she can MOD.
Good job.
Old May 30, 2007 | 04:16 PM
Eric_Rowland's Avatar
Eric_Rowland
Harumph. I would have pegged you for the stealth black ones.
Old May 30, 2007 | 04:23 PM
eager2own's Avatar
eager2own
Now, if only you could get a matching pink strut bar . . . that would be sweet.
Old May 30, 2007 | 04:28 PM
ChrisW's Avatar
ChrisW
Now you know as well as I do that girls only put black under there bonnet if they want people to see it.
Old May 31, 2007 | 10:22 AM
batgirlwildcat
Thanks, guys!
Old May 31, 2007 | 10:29 AM
kenchan's Avatar
kenchan
good job and nice write up!
Old May 31, 2007 | 10:35 AM
Mr. D's Avatar
Mr. D
Great job on the photos
Old May 31, 2007 | 11:29 AM
batgirlwildcat
The side benefits to this install were discovering a cracked shock mount and leaking motor mount. Not surprising, or uncommon.
Old May 31, 2007 | 12:46 PM
jefeant's Avatar
jefeant
Other than colorfull, what do you get out this aplication?
Old May 31, 2007 | 12:49 PM
Eric_Rowland
You mean there's something else?
They are supposed to help eliminate 'mushroomed' shock towers by dispersing the energy involved. Do a search on 'mushroom' for details and examples.
Old May 31, 2007 | 12:50 PM
batgirlwildcat
M7 Strut Tower Reinforcement Plates
Through the years, customers and friends with MINIs have had one common complaint: the strut towers mushroom after heavy impacts from the shocks and low aspect ratio tires. At a first glance the shock towers take on a slightly convex shape barely visible at a fist glance, but if you would compare it to the original sheet metal, you would find the horizontal plane has been moved as much as 3/8" upwards, throwing the suspension out of any possible alignment fix. The problem will most likely show up as a slight pull either left or right depending on which strut tower is buckled. The M7 SRP will solve this problem by sandwiching the sheetmetal and shock top plate, creating a homogenous top surface that will not bend, even during hard impacts. Adding the SRP to your MINI, is an inexpensive solution to an expensive fix. The plate is made from CNC machined aluminum, hard anodized black to prevent chipping, or oxidization.
Courtesy of www.waymotorworks.com
Old May 31, 2007 | 01:05 PM
89AKurt's Avatar
89AKurt
Great "how it's done" thread!
Looks like I would have to get rid of the tower strut I put on. Top photo, is the black bar a strut bar?
chows4us's Avatar
chows4us
sigh ...
Old May 31, 2007 | 01:10 PM
hemiheaded18's Avatar
hemiheaded18
She had that done before that F150 in the background was even in the air!
Old May 31, 2007 | 01:15 PM
batgirlwildcat
Yes
Old May 31, 2007 | 01:16 PM
batgirlwildcat
We did this at the hobby shop on the Marine base. Not even 5 minutes after I finished, some guy walked up and asked what I'd done and how long it took. I was so proud to tell him!
Old May 31, 2007 | 01:22 PM
Eric_Rowland
<hijack>
We did this at the hobby shop on the Marine base...
You did this on base?!
Now that you've told us, does that mean you'll have to kill us?
Or was that only in Top Gun?
</hijack>
Old May 31, 2007 | 01:24 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
Look at that hottie , umm, umm...the MINI that is Nice mod Mrs. Cat, the pink makes Malibu Stacey even more Malibu-ey.
Old May 31, 2007 | 01:25 PM
hemiheaded18
Is she's gonna kill us, it won't take long because she can just jump onto the Highway to the Danger Zone.
Old May 31, 2007 | 01:28 PM
chrisneal's Avatar
chrisneal
Shoulda done the pulley while you were under there. Nice work!
Old May 31, 2007 | 01:31 PM
Eric_Rowland
Good point, Chris. It's just a few more bolts...
Old May 31, 2007 | 01:34 PM
eager2own's Avatar
eager2own
I did some research on mushrooms through google and have plenty of examples to share.
