will it fit: 215/45 on a rota 16" offest:40
Old May 29, 2007 | 06:48 AM
cvcsmkr's Avatar
cvcsmkr
my mcs is not lowered yet.
but i will eventually be puttint in H Sports or some other lowering springs.
any body else have this combo? any rubbing?
Old May 29, 2007 | 10:03 AM
UKCoopeR's Avatar
UKCoopeR
i am not lowered and that size tire & wheel worked fine for me, now i have 205/45 for less sidewall and better autoX accel. i cant help with the lowered part though...
Old May 29, 2007 | 11:48 AM
camminich's Avatar
camminich
I think there have been some other posts about 40mm offset and rubbing. From what I remember, yes, you will have some light rubbing with 215/45 R16, lowered, and 40mm offset. It's the offset that will kill you. With that 215 you really need something in the 46 to 52 range.
But again, we are only talking about "light" rubbing, which does not bother some people.
Old May 29, 2007 | 07:16 PM
wscruiser's Avatar
wscruiser
Well, I got a little different set-up; 215/45/17 tires on 40mm off set wheels; at stock height, and do not have a rubbing problem. I've been running that set up for about 1500 miles, and have been over some really rough roads and dips, and so far I've yet to hear it rub, or see any signs of rubbing.
From the aspect that I'm running 17's and you're looking at 16's, I think you should be alright.
One thing I'd recommend while shopping for tires; look at the specs of the tires and compare the overall height of the tire. Even though the tire may be marked 215/45/16, there may be a slight difference in overall tire height between different brands.
Gabe3
Tires, Wheels, & Brakes
16
Apr 16, 2016 07:55 AM
DrFraserCrane
Aug 30, 2015 01:11 PM
BowserKart
Aug 20, 2015 01:24 PM
Dashdog
Aug 10, 2015 06:17 AM
wheelspnr
11
Jun 23, 2005 12:54 PM
