Suspension So what is the Choice suspension (coilovers/shocks/spring) for the Mini?
Old May 24, 2007 | 06:13 AM
gotundersteer?'s Avatar
gotundersteer?
Just wanted to scope out what everyones running. I know if the Focus community, the choice setup was H&R Race Springs with Koni Adjustables.
What do you guys recommend, thats under $1500?
This will be primarily for the street, autocross, and a good bit of track days.
Old May 24, 2007 | 07:13 AM
satay-ayam's Avatar
satay-ayam
I'd think about better tires and camber plates before anything else.
Old May 24, 2007 | 09:00 AM
gotundersteer?
Aight, yea, check. I have more than a few sets of tires in the garage (T1's, RT615's, V710's, etc).
Now, back to suspension.
Old May 24, 2007 | 09:03 AM
Darkness's Avatar
Darkness
Koni's, H-sport springs and competition swaybars
Old May 24, 2007 | 09:55 AM
PirateMini's Avatar
PirateMini
if I had 1500 for suspension I would get this on my door step tomorrow...
KW V2 Coilovers:
Twin tube oil pressure damper technology is combined with height adjustable threaded chassis and lowering springs. These adjustable rate stainless steel dampers have a specially modified rebound range and low RPM sport valving that is matched to each application's lowering range, from 1.48; to 3.5"; (25.4mm to 88.9mm) in the front or rear. This combination provides the lowering range that enthusiast's desire, with the ride characteristics for which KW is famous. Dampening is controled by an adjuster atop each shock allowing you to control how quickly the shock compresses.
Kit includes 4 stainless steel dampers, damper adjustment tool and springs and full instructions.
Old May 24, 2007 | 12:12 PM
blammo's Avatar
blammo
I've done JCW springs, Koni FSD struts, H&R 19mm rear sway, and Ireland front fixed camber plates for maybe around $1500. Ride is definitely improved, and the handling feels a lot better (although some of that may be mental... I really don't push my car hard enough often enough...).
Old May 25, 2007 | 03:58 AM
satay-ayam's Avatar
satay-ayam
OK, skipping tires and focusing on suspension, then, I still think that if you want to be fast, I'd look at camber plates before springs/swaybars/anything else.
So if you have $1500, the camber plates will be ~ $500. So that leaves about 1k.
I'd probably buy some koni's or bilsteins, a rear swaybar, and some springs.
Old May 25, 2007 | 06:06 AM
sprp85's Avatar
sprp85
megan
nomar116
Aug 10, 2015 11:24 PM
Aug 7, 2015 09:51 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
