Suspension Megan coilover instructions?
Old May 21, 2007 | 05:16 PM
sprp85's Avatar
sprp85
I have looked at some pictures of the coilover and it seems to be a straight swap with stocker
Is there anything that I should look out for?
Also, how do you change springs on the megan? must disassemble the whole fronts (camber plates and all them) ??
Let me know! Thanks
Old May 25, 2007 | 07:41 PM
Wagnbat's Avatar
Wagnbat
It is pretty much a straight swap. Instructions included with the coilover.
Why would you want to swap the springs? I just had a tuner swap my springs because Megan sent me the new ones (old ones were the wrong rate)... tuner didn't mention anything about special tools needed, so I assume as long as you have an automotive suspension spring compressor, you should be good.
Old May 26, 2007 | 12:42 AM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
Dont need the Compressor with the megan to swap them. Just lower the bottom perch and there will be no tension on the spring. As for the rates depends on what you plan on doing with the car and your driving style. For street and light track work the ones that come with the car are ok (8kg/6kg). For me i change the rates to approx a 8.5kg in the front and 7kg in the back due to my own prefences.
Old Jun 4, 2007 | 09:38 AM
DmOcRsI's Avatar
DmOcRsI
You just need a 17mm for the top and maybe a 5mm Allen Head to hold the shock from rotating, that's all. It's pretty simple.
Old Jun 4, 2007 | 10:17 AM
SRTech's Avatar
SRTech
Let me know! Thanks
The original Megans came with no installation instructions. Imagine that. I had three sets come through and they all had no instructions. Maybe later sets did, but not the early ones.
Steve
RIchard Nguyen
Sep 14, 2016 11:43 AM
CooperSharp
Oct 12, 2015 09:21 AM
OldElvis
Oct 5, 2015 07:31 PM
FatherG
Oct 3, 2015 05:06 PM
rt808
Sep 29, 2015 12:30 AM
